WhiteStrat
Don't stare at the eye.
My pair of 603s finally arrived today. Yippi-ki-yo-ki-ay!
Which we all know is Latin for "I'm in love with the UPS guy!"
This is what psychologists call "projection."
Ya got me. Psychologists trump Latin any day of the week.
Dang DrBill that was right nice of you.................dang nice.
What would one man do with 5 603s's? Somthi'n shady thats what!
3-4 for toms, 1 for HH, 1 for Snare. He seemed to want them, so.......why not. I already have to many mics.....
https://homerecording.com/bbs/showthread.php?t=267508
(see pic)
Looked at the pic. If you put as much thought into mic placement for recording as you do for the pic then you're probably pretty damn good. All the symmetry - Neumann in center, Beta52 vs. AKGD112, SM57 vs I5s, twin towers of dual ribbon and MD441 etc. Wow, thought provoking. I laughed, I cried, it was better than Cats!
LOL
Yeah, but did you listen to the RESULTS. You might cry even more when you see how much (and little) some of your favorite pics cost. I'll tell you right now, I paid under $500US for what some consider the top 3 tom mic choices - that's 9 mics for less than $500. Since I'm on this thread I can tell you that one of those choices was a 603/604/991, and another was a previous stupid deal of the day. CAD M177. Beating out Gefell's, Neumann, AKG, etc.
PS - you have keen powers of observation!!!!!
I know Marik has some good advice with these which probably goes beyond the first step there, but I don't know what he recommends.
So you're saying that the .22uF stack metal film cap I used on the mod I did should have been a 1uF instead?There are a few simple tricks with the 603 modification you can turn it into quite an awsome mic.
The easiest and obvious is cap replacement, where the 0.22uf ones should be increased to 1uf, and use your favorite 1000pf type for the input one.
Yep! It has one. Now what?I saw at least 3 different revisions of the input FET biasing, where only one is correct (of course, if adjusted properly), which is with a pot, as in original Schoeps circuit. Otherwise, the headroom is compromised. Open the mic and check if you see a blue adj. pot next to the input FET.
And where would one get this kind of work done? Thanks.The best capsules for the 603 were in the very first revision, where beside concentric groves, there were also machined additional cross paths. Later, this machining pattern was dropped for sake of ease of manufacturing, resulting in considerable low frequency loss--usual complaint for the 603. Remachining the capsules can significantly boost the LF end, turning this mic into real world class mic.
Best, M
A trick to prevent short circuiting is to strip the shielding off a wire about the same gauge as the leads, then slip the shielding over the leads.I managed to get these yellow ones in place by leaving long leads and tucking away -- being careful to avoid a short, of course:
OK first, here are the mics stock, with the victim capacitors indicated (my mics do not have the trim pot that Marik mentioned...
next, here they are with the input capacitors swapped:
the replacement 1000pf poly-something capacitors are a little bigger physically than the stock ceramic (also 1000pf) ones, but they fit fine.
next, I decided to follow Marik's advice and go with 1uf capacitors to replace the .22 ones -- I quickly realized that I had a form factor problem -- my first choice of replacements just didn't fit at all (actually, my first choice are these WIMA ones that would probably fit, but I only had one of them left !!! argh!!!). I managed to get these yellow ones in place by leaving long leads and tucking away -- being careful to avoid a short, of course
even better, I think - more bass. And again, quieter.
Next, I'll have to figure out how to remachine the capsules with my teeth
good things take time -- I've been traveling a lot recently, including much of next week, so that works out perfectly.P.S. I am still not done the 6802 and wanted to do a couple more things. The end of this week we have a baby shower and the whole house now is crazy and full of out of town visitors, sleeping in every possible room--parents, sisters, borthers-in-law, colledge friends, and all that stuff .
Will try to finish some time next week
Look like polystyrene ones--a major step up from ceramics. To my ears not as transparent as some premium polypropelene capacitors, but still good
