Drum Mic Madness!!
  • Thread starter Thread starter drBill
D
drBill
Hey Guys!!
I posted this on "another" forum, but since I've been hanging out here more lately, I though I'd put it up here as well. I wish I had the GB mics to throw into the mix, but.....couldn't wait on this one. I'll probably do another after I get those mics as well.
So......you guys want to settle in for a little fun? Might take a while, there's a LOT of files and a bunch of pics as well. And almost as many surprises for those interested enough to listen critically.
Some of you might remember my last shootout:
http://www.gearslutz.com/board/gear...s/150891-ribbon-madness-some-comparisons.html
Lots of great comments from all of you, so I wanted to get you in on this one as well.
I did a recent drum mic shootout with Craig Bunch. This is NOT a scientific A/B test, but it was a lot of fun, eye opening, and did get way out of hand and seriously over the top pretty fast. heh heh Just a simple comparison of a BUNCH of mics, right???? Well.....not quite.
For this shootout we tried to keep the parts played as close as possible and levels as close as possible, but the transients of the drums themselves fight against consistency as we switch between ribbon, condenser and dynamic mics. Suffice it to say, they are CLOSE in volume, but not perfect. Please take that into account as you listen.
We have a lot of high end mics involved -- and a lot of low end ones as well. Here are the victims:
I learned a lot of things over the course of a couple of days. First, throw what I've been doing "out of habit" for the last decade out the window in favor of taking the road "less traveled". Second, keep an open mind. Third, prepare to be blown away with new mics and techniques. Fourth, don't let a price tag fool you - whether high or low. And Fifth, start saving for more mics. heh heh
In an effort to really let you hear the mic as it should be heard, I've put these clips up on my server as full 16/44.1 uncompressed files as well as mp3's for those of you without broadband. If all of you start hitting me hard and it starts to kill the server, I'll have to take it down and figure out some other way. heh If enough of you are really interested in checking it out seriously, I'll make a DVD available with mixed audio files as well as Pro Tools sessions so you can "remix" and play with the different mics in more detail - for a nominal cost.
I'm not going to tell you which mics I used until later. We made some unusual choices. Some were fantastic surprises. Others were a failure. But all were educational and will help us get better sounds in the future. Most of the mic placements on the drums are pretty standard choices for continuity purposes.
My partner in crime for this extravaganza was Craig Bunch - LA Session Drummer - lending his incredible feel and great ears. Craig is in process of starting a studio of his own and really wanted to listen to the usual suspects as well as some unusual choices - as objectively as possible. Craig is a member (really more of a lurker) of GS and his moniker is "recordingcustom". He used a brand new set of Yamaha's top of the line drums. I'll let him chime in with what he used for heads, tuning, cymbals, etc.. We tried to choose an appropriate groove or pattern to highlight the drum / mic in question. They are often different for different drums. (ie: the HH groove does not have any toms played during it, but the tom groove has a LOT of toms all over the place.) Different grooves to highlight the drum in question. Hope that makes sense. I think it will as you begin to listen.
Here's the low down on how we recorded his drums:
Kick & Hat went thru API512B's
Snare Top and Side went thru API 512C's
Toms went thru the D&R OrionX pre's in my console
Overheads went thru the D&R OrionX pre's in my console
Mono Room mics went thru the Purple Biz
Stereo Room mics went thru the D&R OrionX pre's in my console
Cabling is Mogami for the most part.
All pre's went WITHOUT ANY EQ OR COMPRESSION straight into Pro Tools HD3 Accel via Digidesign 192 converters. There is no processing of any sort anywhere in the signal path. No EQ, No Verb, No Compression, etc. Any ambience you hear is the room.
Please see the pics scattered throughout for placement, room treatment (or lack thereof) and layout.
IMPORTANT : On each clip, you will hear the mic in question in the "overall drum mix" first - AT A SOMEWHAT HIGHER LEVEL THAN IT WOULD NORMALLY BE MIXED AT (FOR DEMO PURPOSES), and in a "groove" situation. Then, you'll hear the drum by itself with all the other mics "open" and lastly just the mic solo'd by itself - all other mics muted. This should give you a better real world idea of how the mic really sounds in the "drum kit" during a groove, with all the other mics open, and finally solo'd by itself. For my purposes, putting up one mic on a drum source and listening is useless. Those types of shootouts don't do anything for me.
So......
Let's get to it:
GROUND ZERO: The mics that are normally up all the time during these clips until it's time to switch out mics for the individual drum/mic in question:
Kick - inside placement - Sennheiser 441 (Craig's request)
Snare Top - Shure SM57
Snare Side - Audix i5
Hi Hat - AKG C451E w/ CK1 capsule
Toms - top placement - CAD M177's
Overheads: Gefell M71S's in a spaced pair configuration.
Room - M.Joly modded Apex 205 - 4 feet up and 6 feet in front of kit
These mics have traditionally got a good sound out of Craig's kits in my room.
I'll post each mic test in a seperate post. Stand by for clips!!!
Inside Kick Mics
First up are the kick mics. First we'll do the inside kic mics. For our purposes on this shootout, we tried EITHER inside OR outside. Not both. Normally, I'll use both, but to simplify things for shootout purposes, it's either inside OR outside.
Here are 7 inside kick mics to check out. All are positioned identically, even though I'm sure I could get a better sound if we took the time to re-position. That's not what this shootout was about though. It was to get a feel for the "flavor" or the mics, not get it to sound as good as possible. Check out the pic for mic placement. Most are cardiod or supercardiod, but there was one omni in the bunch.
In no particular order: Shure Beta52, AKG D112, Audix D6, Sennheiser 441, Sennheiser 421, Shure SM57, EV 635A
HI REZ WAV
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick01.wav
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick02.wav
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick03.wav
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick04.wav
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick05.wav
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick06.wav
http://www.mindseyeprod.com/wpdrumshootout/wp02ikick/iKick07.wav
LO REZ MP3
Outside Kick Mics
OK. On to the outside kick mics. We've got an assortment of LDC solid state and tube mics up to check out. All are in fig8 mode. Here's the 5 candidates:
In no particular order: Neumann U87 Fig8, Gefell UM70 Fig8, M-Audio Sputnik Fig8, AKG C414B-ULS Fig8, Groove Tubes AM62 Fig8
HI REZ WAV
http://www.mindseyeprod.com/wpdrumshootout/wp03okick/oKick01fig8.wav
http://www.mindseyeprod.com/wpdrumshootout/wp03okick/oKick02fig8.wav
http://www.mindseyeprod.com/wpdrumshootout/wp03okick/oKick03fig8.wav
http://www.mindseyeprod.com/wpdrumshootout/wp03okick/oKick04fig8.wav
http://www.mindseyeprod.com/wpdrumshootout/wp03okick/oKick05fig8.wav
LO REZ MP3
Hi Hat Mics
Next up, Hi Hat mics. Although I rarely use much of the HH mic in the mix, on really busy stuff, or where the drummer actually retains good control like Craig, I like to use a bit of it to lock the stereo image into place. We've got 8 different examples for you to listen to. SDC's, LDC's, and even a ribbon.
In no particular order: Gefell 692-M70, AKG C451E Hat, AKG 414B-ULS, Neumann KM84, Gefell UM70, AT 3528, MXL 991, Apex 205MJ
HI REZ WAV
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH01.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH02.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH03.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH04.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH05.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH06.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH07.wav
http://www.mindseyeprod.com/wpdrumshootout/wp01hats/HH08.wav
LO REZ MP3
Snare (Top) Mics
OK. The moment a lot of you have been waiting for - SNARES! I almost always use TWO snare mics, but again, to keep things simple, there is a i5 on the side of the snare at a dramatically lower level, with 75% of the snare sound is coming from the top snare mic due to lowering the overheads gain to get a feel for each snare mic individually. To reiterate, for this test, I've lowered the overheads much lower than normal and raised the level of the top snare mic so we can get a better idea of the snare mic in question. Ten mics to choose from!!!
In no particular order : Neumann KM84, Shure SM57, MXL 991(604), Audix i5, Sennheiser 441, BeyerDynamic M201, Gefell 692-M70, AKG C451E/CK1, Groove Tubes AM62, Sennheiser 421
HI REZ WAV
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn01.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn02.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn03.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn04.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn05.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn06.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn07.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn08.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn09.wav
http://www.mindseyeprod.com/wpdrumshootout/wp04snare/Sn10.wav
LO REZ MP3
Tom Mics
Next up are the toms. There were a couple of anomalies with this test. Due to not having 3 of everything, on one of the clips I used (2) UM70 with a M71 - all in cardiod, so they are VERY similar. In addition, I used (2) 414's and a U87 on floor tom on one of the clips. Other than that, all mics on all 3 toms are identical. Hope that makes sense. Again, I lowered the OH mics quite a bit in an attempt to give you a clearer image of the tom mics themselves. Here you go:
In no particular order : Sennheiser 421, AKG414-NeumannU87, MXL 604(991), Audix i5, CAD M177, Gefell UM70-M71S, Shure SM57, Neumann KM84
HI REZ WAV
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms01.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms02.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms03.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms04.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms05.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms06.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms07.wav
http://www.mindseyeprod.com/wpdrumshootout/wp05toms/Toms08.wav
LO REZ MP3
Overhead Mics
OK. Overheads are up next!! This is where things start to get a little messy. If you look in the name of the file itself, it will tell you a little more about the placement, pattern of the mic capsule, and whether it's a mono placement or not. 16 mics / placements to choose from. This is a fun one.
In no particular order : M-Audio Sputnik, AKG C414B-ULS, MXL V69ME, Gefell M71S, Apex 205MJ, Cascade X-15, Neumann KM84, AKG C451E/CK1, Gefell 692/M70, Neumann U87, Cascade Fathead II, GrooveTubes AM62 (A few of the mics are tried in different positions with different polar patterns.)
HI REZ WAV
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH01SpacedCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH02SpacedCardHPF.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH03SpacedCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH04SpacedCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH05SpacedCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH06OverheadBlumlein.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH07SpacedCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH08SpacedFig8.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH09SpacedFig8HPF.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH10SpacedCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH11FrontBlumlein.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH12SpacedFig8.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH13RearBlumlein.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH14MonoCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH15MonoCard.wav
http://www.mindseyeprod.com/wpdrumshootout/wp06overheads/OH16MonoFig8.wav
LO REZ MP3
drBill--
This is excellent work. And a lot of work. I did a mic shootout for guitar cabs that compared six mics. I thought that was a lot of work--until I saw this. Thanks for taking the time.
Now I'm gonna take the time to dig in and listen to the files!
woooahhhh....can't wait to get home and get into this shit!!
cheers.
Cool! Love to hear your thoughts guys! Yeah, it was a lot of work, but worth it.
I'll post up some pics as time permits. I kind of need to get back to writing after that...... :D:D
bp
Wow
As a studio guy AND drummer, I am really looking forward to hearing this.
I wish I did not run across this while at work.....
Now I have to stay all day!.... uhhhh feeling.. sick.... got to go home....
EXCELLENT!!
I normally am not interested in "mic shoot-outs", but THIS takes it to a much higher level. This must have taken a lot of time and effort. Thanks for sharing this useful info.
nice work!!
I d/l'ed all the wav files, so if you need a mirror, let me know.
I'm going to have to break out my "nice[ish]" monitors to listen to these!
Let me add this to the deserved heap of thank-you's! This is great, I really appreciate it.
Excellent! Just the kind of person I'm looking for feedback from. I'll try to have Craig drop by and tell us a little about the drums we used.
WOW Thanks for all the work. I'm in drum mic heaven.
Cool!!! :D
EXCELLENT!!
Chance - my pleasure!!! Especially after all the work you've put in for us....... Looking forward to picking up those mics and pres in Sept and meeting you in person!
nice work!!
Thanks!! Not sure about the mirror though..... :confused:
My pleasure. I hope you guys get as much knowledge and insight out of it as I did. Everybody should do a shootout like this at some point. It really opens your eyes (ears) to a lot of things.
I'll be posting some pics here when I get the chance.
Thanks so much for this! The drums sound amazing! Do you know what kind they are, and what heads were used? Also, could you please post a photo or two of the room that the drums were recorded in?
Thanks once again! :) This must have taken quite a while.
Will post some photos soon. Hopefully Craig wil join HR and chime in on the drums, cymbals, heads, tuning, etc. soon. I know he's been out of town, but I believe he gets home pretty soon.
I know that it is Yamaha's top of the line recording kit. I believe they are maple, but I could be wrong.
We did a couple of days of recording and juggling mics and recorded one drum track for a song while we were at it. The editing and bouncing and naming probably took a day as well. All in good fun. :D:D
As promised.....
Some Pics!
Craig's new Yamaha Kit :
Side shot of the kit :
From the opposite side of the kit :
Kit from the top :
more to come........
cmharwood89
Replies
3
Views
2K
cmharwood89
cmharwood89
Replies
10
Views
3K
Papanate
Papanate
