winzip and what else?
  • Thread starter Thread starter Setherial
Setherial
i have cooledit2k...i don't have a cd burner yet nor a website. but want to at least email some samples (kinda large). saving a .wav as an mpeg then using winzip helps alot to condense it but is there something else? i heard about mp3'ing. is this what i need or is this something totally different??
You can go to www.musicmatch.com and download a free jukebox which will convert .wav to mp3...
Use your editor to select the portion of music you want to share, delete the rest of the file (make a copy if you want to save the original) THEN convert to an mp3 using MMjuke.
Go into the MMjuke... Select Convert / set source and destination folders and select format >> .wav to MP3 128kbits / sec and you have a mp3 you can eMail.
Most paid eMail accounts can send @2meg I think.
zip >>
If the receiving party is going to be USING the samples in a recording, then you don't want to use a lossy compression scheme like mp3. If they are just going to be listening to your final product, then mp3 is a good solution.
Zip compression will work on a wave file, but I'm pretty sure you're only going to see a 10-30% or so reduction in file size (can't remember the last time I did this) so you're still looking at a big file. Zip compression probably won't do much to an MP3 since the mp3 is already very compacted.
As zip said (how appropriate a name in this thread!), email accounts almost always have incoming quotas. Most free email accounts that I've had the displeasure to work with are limited to 1MB incoming. Many paid accounts will be limited to 1-2MB incoming, but the user's mailbox size is usually restricted to a few megs. In other words, don't use email. Upload the file to something like xdrive and have your friend download from there.
(note, if the receiving part is going to be using your sample in a recording, and sending a wave is simply out of the question, then using HIGH quality mp3 (256kbps or better). Also, make sure you both use the same high quality converter. I recommend SCMPX as it's the best sounding free converter I've used. Easy to find and small if you search)
Slackmaster 2000
Another solution is file fission. You break up the .wav into bitesize bits that can be e-mailed separately and then the same program puts the pieces back together on the other end. Voila! Transmission of a full sized uncompressed .wav file. You get around the mailbox size limitation by synching the reading (downloading) of the chunks with the uploading, so that there is never more than one chunk in the mailbox. It can be done. But it requires some cooperation between the parties doing it.
I would just upload them to one of these free sites that offer storage space and upload the waves there, where they can be downloaded by the user......
monkeys audio??
Hey PG....
Do MA compressed files work with most players??
zip >>
I downloaded and I'm gunna check it out. Thanks man.
