Window insert - acrylic or laminate? Or something else?
  • Thread starter Thread starter CharlotLouie
C
CharlotLouie
Looking into DIY window inserts to get rid of some road noise. There will be an air gap between the actual windows and the inserts. Will put the insert inside of a frame, surrounded by tubing, or weatherstrip, or something, not sure yet. I am still in the planing stage.
What is better to use - acrylic or laminate? Or something else?
Thanks.
glass. 6mm at least, ideally get a double glazed panel just smaller than the existing glass, and attach with velcro. Plastics just don't have the mass to work very well, unless very thick.
Also worth remembering that if the window frames are PVC, they're hollow for thermic value and the frames often leak more than the actual glass in them!
Laminated glass is fine - I have done windows from room to room in my studios with both plain float glass and laminated and didn;t notice any difference - It might be worth checking with a local double glazing firm - the last time I got wrongly measured, scrap double glazed panels for silly money. If they have one just a bit smaller than your window opening, you could knock up a frame and a fixing?
When I redid the windows in the house years ago, I went with triple pane, and it dropped the sound level significantly from the original single pane windows. It also stopped the condensation on windows in the winter. I run a humidifier in the winter and at temps below freezing, water would often condense on the glass.
For my windows, I have double glazing, but specified that one of the glass sheets should be laminated.
This means there is a total of half an inch of glass between inside and outside.
That considerably reduced outside noise.
However, shortly afterwards, I had a woodburning stove fitted including a metal chimney.
They also had to drill a vent through the wall for air intake.
When there is noise outside, I oddly hear it coming down the chimney first.
I get a bit of noise through the vent too.
