spitzer
I'll add more detail later (not too much later I hope). Anyway, a simple concept and a simple question to start with. I'll say right now that I'm looking for just a slight improvement and I'm not going to do a TON of work.
So, there's a drum set in the corner of the room right next to a plaster cement (part plaster, part cement, on the harder side so de facto, concrete) coated brick wall. On the other side is a bedroom. The issue is twofold: attenuating the sound getting through to the bedroom and making the acoustics a little nicer (obviously the drums sound... a certain way with a VERY hard wall on one side and lots of air on the other side of the space).
What I'm thinking is basically building a 2 m long, 1,5 m tall, 12 cm deep (7 ft x 5 ft x 5" for the Empireans) panel. It will have a 2"x4" frame, and the outermost layer is beadboard. I also have extra chipboard I can use for something if necessary. The panel would be attached to the wall right at the corner, with felt, carpet or something else underneath to dampen vibrations. The inside of this panel is going to be filled with something, which is an unknown at this time. Ideally something that would also make it a bass trap/low frequency absorber. I edited this to reduce the confusion I for some reason caused by first saying I would "basically nail a wooden box to the wall". Which is still 100% true, but most everyone misunderstood it to mean something totally different than what I actually intended. I changed the topic for the same reason.
Ideas on this concept? I will mention that I am aware of flanking and such things, BUT I don't think they're that important here. I left an SPL meter in the bedroom and from there, it registered a max of 60 dB [*] in the current circumstances, so like I said I'm looking for a SLIGHT improvement, not complete isolation. Before anyone mentions it, floor vibrations are already handled.
If anyone has information on which way a drum set primarily projects the sound, that would be appreciated. I'm unable to do a complete "sweep" of that kind myself. The bass drum alone with the mic one meter in front of it gets me peaks between 90 and 100 dB with "typical loud" kicks. Years ago, I did register 142 dB (!) from above a snare drum but that was a very loud hit not really within normal playing dynamic ranges.
And regarding this box/panel, what would maximise low frequency attenuation within these constraints? Keep in mind that these aren't exact plans at all, I can make it slightly bigger, I can make it slightly thicker, I can increase the air gap a little bit, but I don't want to make it excessively big. The room is small enough as it is. I have a little bit of extra chipboard lying around that I could use, currently it's actually just in the way and at least I'd have more floor space even just nailing them to the wall!
Thanks in advance.
[*] That was hitting the kick, floor tom and snare only. I was purposely concentrating on the low frequencies (snare solely because even though it's HF, they tend to be loud).
I realise this is a very complicated an extremely unconventional solution, I don't need any reminders about that. Also, since it's an unbelievably frequent suggestion: I am NOT going to treat the entire wall. Period. Please understand this. I'm interested in and would hugely appreciate any information that would maximise the performance of what I am actually going to do. Please understand this is also an experiment. And please understand that if it completely fails, I will have no trouble dismantling it and doing something else in it's place. I am completely fine with that. I am not interested, AT ALL, in suggestions to do something else, I'm interested in the science and mechanics of THIS concept and this concept only.
Best wishes.
Thanks in advance.
Best wishes.
