Nick The Man
which do you think is better
please state why
please state why
Warhead said:It sounds better, isn't PCI based (man that shit's dying) and has "decent" preamps on board.
Tis better...I've used both.
War
Clit Torres said:Looking at the poll, I'd say he was talkin about the Firepod.
Personally, I've used both the Firepod and own the FW1804, I wouldn't say either is better. If you check the specs they are fairly different, the 1804 has more flexability in terms of I/O, and the Firepod has 8 built in pres as opposed to the Tascams 4. And like War pointed out, the Delta is PCI based so that to me would also fall into a different category.
So I'd say none are better, just different.....
Nick The Man said:but if all the qualities are the same shouldnt i go with the M-audio becuase its cheapest
Clit Torres said:Actually if you read my post I didn't mention anything about the qualities in these units being the same.![]()
Like I mentioned before, they're all different and have different feature sets, so go with the one that will suit your specific needs. If the 1010 has what you need and it's the cheapest, seems like a no brainer to me.
fraserhutch said:Features smeatures - useless if the sound isn't up to par.
I'd say go with the one that has better convertors (I don't know which that is).
Clit Torres said:I can't really speak about the Delta 1010, but I didn't notice any difference in sound quality between the Firepod and the FW1804. Although, I did hear a drastic difference between the converters in the FW1804 and the Edirol UA700 I was using previously. So basically between the two, IMHO, figure out what features you need, then pull the trigger.![]()
Clit Torres said:I'd go with the Firepod if expandability is not an issue for you and you're not intending to use any other pres, otherwise I'd go with the FW1804.
rockcamaro97 said:guys, just picked up a firepod today so in a few weeks hopefully ill have a nice review to post.
Matt
War
