E
		ecc83
The only "safe" meter to look at is the one in the recording software because different interfaces/soundcards have different sensitivities.
My own 2496 cards for instance hit 0dBFS for ~2V in and so when I run my ZED10 at 20dBish below that the (excellent but useless here!) meters on the mixer are barely showing.
No audio interface I am aware of has other than one gain control per channel (maybe a pad) and so there can be no gain staging, just crank for neg 18 or 20 in the DAW and you'll be right.
FYI: The actual converters have an very low overload point of just a volt or two so when you see "pro" interfaces that run -18dBFS at +4dBu this is the result of some very carefully designed, very wide dynamic range electronics.
