M
macthedoulos
anyone have any good tips on basic compression settings for hip hop vocals? what should the threshold, ratio, attack, and relase be set to?
macthedoulos said:true....but i've messed around...i just need to know some industry standards if there are some. ya know? like....i'm sure every engineer major studios fool around until they get the right sound for the vocalist/rapper....but i would think that they also have certain standards or places they start as well. a mental template if you will that they adjust according to how it's sounding. like....."ok...today i'm doing hip hop so i'll start with the threshold here and the ratio here and build from there. tomorrow i'm doing metal so i'll start the threshold here and the ratio there and the atack here..."
do i make sense? hopefully....
And those are two terrible paragraphs to quote. The fastest attack will absolutely kill all the highs at the start of a note. If you must have starting points for vocals, around 20 to 30ms for attack and about 1/2 sec (500ms) for release would be far better, at least it would do less damage to the vocals.mattkw80 said:Setting Attack and Release: These settings can be tricky as they can "delay" the effect of compression on the attack and make is hold on a bit too long on release if set improperly. I suggest till you get these tricky settings figured out (which takes quite a bit of experimentation) you simple use the fastest attack and enough of a release so the vocal is not boosted as the word trails off. Otherwise a word may pump on you unnaturally.
Setting the output: This is the final adjustment as the signal leaves the compressor. It's sometimes called the "make-up gain". They call it that because compression often lowers the overall signal and you may need to boost it back up. Basically you want to optimize this so it does not ever go over 0db in the recorder. With luck you should see a consistent healthy level on the recorder's input meters regardless of how loud the vocalist is singing.
(I stole those top 2 paragraphs from a website).
mattkw80 said:I thought you were asking a good question. Too bad all you got back for an answer initially was basically :
"Just do it. Just try it. Just get it done. Play with the knobs."
RAMI said:Those were the best answers anyone could have given him. Throwing out any numbers at all under the guise of being helpful is doing the exact opposite. He needs to educate himself and learn through trial and error and experience. Or is that too "old school"?![]()
corban said:Part of the problem was his question was pretty specific. "What should the threshold, ratio, attack, and relase be set to?" There's no answer to that. Sure, some guidelines can be given, but that's dangerous cause then it's way too easy for him to just use those settings as a preset on every vocal he ever does, and never learns a thing about compression on the way. With everybody's answer combined in this thread as a whole, he should get a starting place as well as a strong impression that compression is not a "set it and forget it" tool.
