Strave
Innovations said:Better than that, go to the store and get the following:
(a saw, drill and screwdriver if you don't already have one)
5 sheets of 3/4 inch MDF plywood
Some angle brackets
some caulk
A pair of spring loaded door hinges and a surface catch.
Some Weatherstripping.
Then put these together in the form of a four foot square seven foot high big box with one spring hinged side with the caulk and weatherstripping to prevent leaks.
Then go to an insulation supply house and get a bale of 3 to 5 pound per cubic foot fiberglass, Owens Corning 703 or equivalent. Also get to a fabric store and buy about ten yards of craft felt, your choice of color. Wrap two inch thick panels of fiberglass with the fabric and hang on the walls, you should be able to get about a dozen.
This will get you better performance, both in terms of isolation and absorbtion than anything discussed up to this point. It will be close to your budget too.
Good suggestion for a permanent booth... but he wants something portable...
