A Reel Person said:as on any other day you might get a fully functional 464 for the same price, on Ebay.![]()
A Reel Person said:Provided it was a fully functional unit! Local pickup is best, because at nearly 90 lbs, it's a bear to ship!![]()
Hi_Flyer said:464s were the precursor to the 424s right? sorry $125 doesn't sound like a great deal, you could probably grab a 424 with 4 working channels for the same price on ebay... I think a brand new one will run just over $300.
Hi_Flyer said:They still make 424s, not 388s though...
A Reel Person said:and that's an awesome deal.
It's hard to compare the 488 to the 424mkIII, because they're slightly different in almost every area.
The 424mkIII has 4-tracks on cassette, and the 488 has 8. 4-tracks on cassette (424mkIII) would sound more robust than 4-tracks (out of 8/488) on cassette, but overall fidelity should be roughly the same between the 424mkII and 488. It's when you go into track-bouncing scenarios on the 4-tracker (424mkIII) that you'd be better off with the straight 8-tracker (488), because bounced tracks will compromise fidelity. I hope that's not confusing.
The 424mkIII has a mid-sweep 3-band EQ, and the 488 has 2-band fixed EQ,... so the 424mkIII edges out the 488 on EQ.
The 424mkIII has 4 XLR inputs, and that's nice, but the 488 has none,... but all 1/4" inputs.
The 424mkIII & 488 have different displays, with the 424mkIII's being a bit more modern, & with better visibility.
If you're talking about a 488mkII, it's a slightly better version than the 488, and would be more on par with the features of the 424mkIII. The 488mkII has the same EQ as the 424mkIII, same display, plus features 2 XLR inputs with phantom power, which seems to be the sought after feature these days.
Aw heck,... get'em both!![]()
marathonman said:how bout the 388 for 175?
Mark7 said:If you want to hear some stunningly good recordings done on a humble 488 and 244 click here.
Anyway, just another log to throw on the fire.
cjacek said:Yeah, take a listen to some cuts done on the 388:
http://www.nowhereradio.com/artists/album.php?aid=1609&alid=-1
(1) God
(2) Long Time Gone
(3) Love Me Do
...among others by Dave (A Reel Person)
(Hope you didn't mind me steppin' in, Dave ?)
~Daniel![]()
). It's another fav of mine! (Currently listenning).
A Reel Person said:I've recorded many times on analog without dbx or NR, and even if there's a hint of hiss on the lead or tail of a song, it's usually transparent when the song commences, & has never been a deal breaker in otherwise normal recordings.
I see tape hiss mentioned as a problem of analog, & emphasized many times over on bbs posts, and I almost always think it's overstated. Hiss can be minimized, and it often reflects improper use of dbx, poor signal levels, or other noise in the signal chain. YMMV.
We've all been there, dude.myself said:... often reflects improper use of dbx, poor signal levels, or other noise in the signal chain...
marathonman said:i see this thread is still alive!
well guys i've come to my last question for you guys, 424mkIII or the Tascam 414MKII 4-Track Recorder, this is the only thing i would like to hear good discussion on. WHICH WOULD WORK FOR ME BEST?
i'll brief you on my needs ...
i use sonar 3
m-audio 414 firewire with pre on it
RNC compressor
i would like to JUST RECORD VOCALS, nothing more, with the tape machine and THEN DUMPING IT all in sonar 3 producer edition to mix.
and my other question is, they actually use regular cassettes but i saw other tape machines that do NOT use cassettes but tape on that....i dont know what you call it but the tape is wrapped around, just look at the tascam 388.... is there a difference in that? i hope people understand what i mean...
anyway lookin forward to replies, please read everything i just wrote carefully because i've had many questions skipped in this thread...
thanx guys
Now, what I just thought of is that the 424mkIII also has 4 RCA tape outs that you can run into 4 RCA's of your soundcard (if you have that option). That could be beneficial too. But I'm kinda confused .... Do you wish only to do your vocals on one of the tracks or would you take up all 4 ? Sorry to be writing in a chaotic type of manner but I'm just writing as things "come to me". Another thing you may try on the 414mkII is record your vocal on 4 tracks and then dump them to one track (via the L or R RCA outs) but this time ride the faders to come up with one "perfect" take taken from all four. This may take some practice but it's an old recording school type of trick that works good. That way you may not need to spend more on the 424's automatic punch in feature. Seriously, I think you could do pretty much similar things with both machines. Again, it's a coin flip .... Tho I wonder why you don't want to pick up one of those stereo consumer open reel decks ... Can be found locally too and if in good condition will suffice for what you wanna use it for but will sound much better than teh 424 or 414. They run at 7 1/2 ips and have 2x the track width and are arguably much easier to use than the cassette portas for your purposes.A Reel Person said:I've recorded many times on analog without dbx or NR, and even if there's a hint of hiss on the lead or tail of a song, it's usually transparent when the song commences, & has never been a deal breaker in otherwise normal recordings.
Dbx really silences residual tape hiss in most cases, and I usually prefer it, but results are usually decent and acceptable without it. It helps to print levels a bit hotter when not using dbx.
