GuitardedMark
Gee Mark, I got my tech-support mojo workin' but it just don't work on you...
...er
um...
The neatest solution is to solder a lead - as described above.
Plugging TRS left/right into TRS balanced mono is not a solution - as explained above.
The lead I suggested would help you... erm... in the manner described above. To rephrase and reiterate: it would take the right or left leg of a dual-mono left/right output and feed it unbalanced via 1/4" jack into the mono input of your 0404. It would avoid any hot signal leg being shorted, and avoid a dual-mono signal being superimposed out-of-phase. Thus bringing about effective transmission of the might and majesty of your guitar playing, rather than the sinister and enigmatic silence which gave rise to your initial distress.
LOL Rob! You said first the the cable was a solution, twice actually
now you say it is not a solution? I seem to believe there should be a simpler solution than to start soldering, plus I dont have a soldering iron. I'm not a hardcore tech guy. I'm more into making the music and less into how it gets on CD
