P
pappy999
What exactly are the differences between these two tascam machines?
The TSR-8 is a final-generation machine. It is microprocessor controlled (smoother tape handling) and has integrated DBX noise reduction. It has LED bars instead of VU meters, which are less accurate but easier to read IMHO. It also has only one audio head instead of two, which makes alignment more difficult and you can't do a confidence check on what you're recording.pappy999 said:What exactly are the differences between these two tascam machines?
If your aim is to use it as a tape delay, yes. If you want to track to the TSR-8 and play the tape back later, no.pappy999 said:So if I wanted to use the trr-8 as a front end on a DAW then I am SOL?
You'd have to record it and play it back into protools afterwards, lining it up with the other tracks as need be. It can't be done live, since the TSR will only monitor from the input, not back from tape.pappy999 said:I just want to track into the tape machine first and then into pro tools for the warm tape "feel". I will track drums with other musicians playing at the same time. I have to monitor the drums in my daw. Will the tsr work?
pappy999 said:I want the ability to use the tape machine to impart tape "saturation" on my live drum tracks. How do other people do this? I have a live room that I put the drummer in to track with band over headphones. The band in the control room need to be able to hear the drums in real time. Any thoughts?
Of course any other tracks which are going direct to digital won't be, and you cannot do this trick with the TSR-8 because it's only got one audio head. The '38 would work, though.Beck said:If you have good isolation between your live room and control room it's a cinch… just feed the band’s monitor mix from the playback head of the analog deck. That way they’re in sync with the delayed sound.
jpmorris said:Of course any other tracks which are going direct to digital won't be, and you cannot do this trick with the TSR-8 because it's only got one audio head. The '38 would work, though.
Beck said:I tend to shy away from manipulating time (or doing any editing) in the digital realm since that's more opportunity to corrupt the material.
pappy999 said:What if I recorded everything into Pro Tools and then sent the tracks into tape? Any experience doing this? Would we get that desired tape "sound" this way?
