Myriad_Rocker
Innovations said:If you decide that you do not want to frame, maybe because you like the soft look, then the typical solution is to use impaling clips.
http://www.acousticalsolutions.com/products/hardware/impaling_clips.asp
If you want the panels stood off from the wall a distance then screw blocks to the walls and then attach the impaling clips to the blocks.
<whisper> Pssst...I already decided. Check above... </whisper>
