JDOD
therecordingrebels.com
How do I download one of those clips, Greg? They just play in my browser.
Cheers, mate. I was being a fucking pleb.I think just right click, save as
Haha yeah that's how I imagined it when I first heard it. That's like 80s Judas Priest or Maiden kind of JCM 800 tone that I was talking about. The flub isn't so bad in the mix. Very meaty, tight mids, articulate highs.Cheers, mate. I was being a fucking pleb.
Here's the mix with your clip. It certainly adds the meat I'm after but there is a bit of flub in there too. Your amping is panned 50% right. My rhythm track is still 50% left where it was before.
Cheers, Miner. Yeah, its a little mushy, but that's probably more to do with my signal. Sounds great though - SD1 clip is my favourite, for similar reasons to when I was listening to Greg's clips - the palm muting is tighter.Here's Jdod's clip ran through the EVH. I did 2 takes, one with an SD-1 (clean boost), & one without...
Signal chain:
DI>EVH LBX> V30>i5 (I did lower the di's item volume -3db in Reaper to keep it from clipping)
Amp settings:
15w mode
Red channel
Resonance:........2-3
Bass:................8
Mid:..................2
Treble:..............7
Presence:..........6
Gain:................3.5
Volume:............4
JDOD EVH
JDOD SD-1 EVH
It probably would've been better using the blue channel with the boost, but it tighten the red channel up a little...
I think part of the mushy-ness is due to the di being tracked so hot like Greg mentioned. You might wanna drop the pre-amp gain on your interface a little dude...
Drop the height of the duncan a bit. It will help with the clipping as well as giving you more string to string definition with higher amp gain.
16k? Thats fucking hot. Definately try the above.
Since the low end is mushy in your clips too, I have to just assume it's the character of that pickup combined with being tracked scorching hot. I know JBs are very popular for hard rock/classic metal tones and have been for a long time, but that's exactly why I don't particularly like them. All of the JB experience I have results in the same thing - mush. A friend of mine had a Strat and a Les Paul with JBs in each. Both guitars sounded mushy to my ears. They're just too much. Too hot, too fat, too bright, too everything. I suppose at their inception they were great because amps didn't have much gain. A smoldering pickup pushing a mild amp is a good thing. Now, with amps the way they are, I think people should choose one or the other. Hot pickup, or hot amp. Pick one and go. Both being hot is a recipe for mush. Just my opinion.Here's Jdod's clip ran through the EVH. I did 2 takes, one with an SD-1 (clean boost), & one without...
Signal chain:
Amp settings:
15w mode
Red channel
JDOD EVH
JDOD SD-1 EVH
Ah,
this image is probably almost as old as the film clip.
One's amusing and the other is a work by a band in a BIG slump.
I will probably try this actually. It might make a fairly big change to the sound of my whole rig.
Yeah use something like a machinists scale or calipers or something. It only takes....in your language....millimeters. Fractions of millimeters. I usually do mine 1/4-1/2 turn of the adjustment screws at a time.I'll definitely try lowering the pickup slightly to see what effect it has - I do like the sound I'm getting at the moment but it can be a touch harsh. Maybe lowering it will just take the harshness out of it.
I'll make sure that I measure it beforehand so I can get it back to where I am if it goes wrong.
That kinda shocks me in a way, because a lot of the 80's players I like used that p'up...
