minerman
Tonetard
No, not the EQ guy. Just someone who keeps posting frickin' "tutorials". Not important.
Lol...ok since I don't know, then I don't wanna know...
Before you try putting an od after the fact, put it on your di track & run it through the amp Rami....I've done this before, & actually had pretty decent results....The SD-1 in Amplitube is pretty close to the real thing, so you might find something that'll work dude....For the slide, I'm going to try putting a virtual overdrive pedal on that track to see if if gives it a bit more sustain. But since an over-drive pedal usually goes before the amp, I'm not sure if adding it to the post-amp sound will work. I'll find out later.
Thanx a lot, Miner.![]()
