miroslav
Cosmic Cowboy
Speaking of tone.... I just ordered this baby a few minutes ago. I played one already and can assure you that it definitely has some sweet tones! Can't wait for next week! LOL!![]()
I've had the same amp/cab setup for about 4-5 years now...it's a beautiful amp. It has a lot of great tones.
Two things I didn't like about it that I modified....both are personal taste things, so to each his own.
1.)The short spring reverb that comes with it was/is just too hard/bold and in-your-face with just a slight turn of the nob. I could not find a "subtle" setting. So, I found a long spring vintage/original Accutronics tank that I think came out of an older Carvin amp, and that had different impedance values than the stock tank in the Swart (I'm not in front of the amp at the moment to give you the exact tank model numbers....and it sounds much better than the stock unit. It isn't as hard/bold. Also, because it was a long reverb tank, it could not be mounted back inside the head cavity, so I got a really nice padded reverb tank bag that I hung off the bottom wood panel of the 212 cab. I screwed it to the inside, then flipped it out and over...so it hangs on the outside of the back panel of the 212...with a couple of longer RCA cables, and it worked out really well and sounds much better.
I left the stock tank still mounted inside the head.
2.) I didn't care for was the pair of Celestion Greenbacks it came with...so I took one out and replaced it with a WGS Reaper....and the combination was sonically more diverse than with the two Greenbacks....but that's also personal choice thing.
Not sure if they still come with a pair of Greenbacks
Otherwise I love the amp and it gets the most use out of my amp stable. Try the Lo Input, but with the switch set to High.
Oh...there's one more thing I wasn't crazy about. The Tremolo is beautiful...but it doesn't go REAL slow, like I can get with my Savage Macht 12X (the tremolo on it is to die for). So I talked to Swart and he has a mod that requires you to simply replace the Trem pot and I think one resistor. It was actually easy to do...so I went for it.
Only thing...it didn't slow up the Trem like the mod claims it would, and when I talked to Michael Swart about it, he admitted that the mod was meant for one of the other Swart models which has a slightly different Trem circuit, but he thought it would work the same on the SST.
While it didn't slow down the Trem more....it actually changes it in a good way, IMO...because you can do some other Trem flavors depending on how you manipulate the speed and depth knobs, that the stock Trem setup can't do....so I was not totally disappointed that I did the mod. It was only like $15 for the parts from Swart and about 30 minutes of some basic soldering.
Get read to enjoy some serious play time with the SST!!!
