Sedge68
So, progress report; but first, here's how I figured to handle the US-800 power cycle issue; I took advantage of one of (in my opinion) the US-800's minor weaknesses; the power cord is a two-part affair - an AC power cord that connects to a AC/DC adapter box and cord, which is better than a wall wart, but the AC power cord is both short and loose-fitting. So, instead of plugging in to the power strip on the floor, I plugged it in to the power conditioner in my compressor rack, and made sure that the AC/DC adapter box was near at hand. I could then power cycle using the loose connection of AC cord, instead of trying to mess around with the back of the US-800 box, and risking damaging the internal solder connections to the US-800 chip board, or any other part of the power input on the US-800.
Now, that sounded like a great idea; however, I never really got the chance to test it, because I never needed to reset it! Great news! It seems the problems I was having were all particular to the US-800's control panel. I never even opened that control panel application last night, and was rewarded with flawless operation. I think I can recommend this for everyone; use your DAW to manage the US-800, and avoid interaction with its control panel as much as possible. (Note this may be particular to the Mac version of its driver.)
I also managed to run my mixer much quieter. I was used to running it at about +3db overall. Last night I was able to run it at about -6db. This resulted in very little activity from the clip indicators, and gave me very high hopes for a good recording.
But, high hopes were not reality. Alas, the entire recording was again staticky crap. Another 3 hours of wasted audio. So, it's not the gain or clipping. The waveforms were looking good enough that I didn't bother trying other input device configurations, and now I'm regretting that. I really need to isolate the different input devices and confirm I can get a clean recording from each of them, and if that is the case, then dig into Mac's aggregate audio device a little deeper and see if something in there is causing this. I'm still hoping it's not the US-800; however, if I won't be able to run the aggregate device, then I'll need to step up to the US-1800 anyway, because 6 channels just isn't enough to capture what I want to capture.
So, a very mixed progress report. Valuable lessons learned, though.
Hopefully it could help others, too. Basically, a MIDI signal must not hit the Windows OS without some VST or DAW already running to handle it. So the key is to switch everything on in a precise order: start with the US800 and *ALL* MIDI devices off. Switch PC on. Switch the US800 on. Start up DAW or standalone synth. Set MIDI In in the software to be the US800 (if not set from previous running). Then switch on MIDI keyboard. So far I have had 100% success doing it this way.
