JimmyS1969
MOODerator
I have not a clue about it's compatibility with Mac.
Haven't yet even tried to do any monitoring or utilize any of the outs on the US-800 - when we're live, I've got the FOH and stage sound to listen to, and that keeps me pretty busy. Trying to listen for these relatively brief sections of static while live would be a bit of a PITA. Still, Fri night's show was almost completely static, so I may be able to try this at the next show (this Fri and Sat).Does the static come through on the Monitor out of the US-800? If so it might be some ground loop picking up noise in the mixer..
Don't know yet, but I think at the next show I will be trying some different configurations - I should try a few songs with JUST the US-800.Does the static go away if you don't use the aggregate device?
According to the US-800 panel, the default is 44100. CuBase seems to also be defaulted to 44100. MTS is at 44100.What sample rate is everything doing the recording setup for?
Because that is what is recommended by Carvin. I don't think your solution would work, because with having the jack all the way in, the board would be expecting a return signal to complete that signal path before going through the rest of the channel controls on the board. (From Carvin manual - DIRECT OUT -Why are you half inserting your insert cable? Isn't that risky? I made my own stereo to mono cable using actual stereo jacks on the mixer board (tip and ring soldered together) and mono jack going to the US-800..
Perhaps the best question! I must have thought Reaper was PC-only. I see that it is available for Mac as well, and will likely be giving it a try. Still, the simpleness of MTS is really nice, compared to how complex CuBase was. Again, I'm not mastering or really doing any post-processing yet; I just need to record 10-12 clean signals. I've been giving those wav files to someone else who is doing the post processing in GarageBand, I think.Why are you shelling out money for a DAW when Reaper is free to try?
Well, I didn't see anything there. I'm actually thinking my problem is with running into a lack of headroom and a 0db limitation with digital recording.I'd double check your preferences for ajusting sample rate..
No. The board has a SPDIF out, but I haven't messed with it yet. It doesn't really seemed purposed for what I am doing.Doing anything with SPIDIF? If so, need to set everything to 48000...
Plug a 1/4” mono cable “half way” into the Channel Insert Jack. The “half” insert connection creates a send signal without breaking the channels signal path. The insert in this mode is no longer used as an insert but becomes what is called an DIRECT out.)
Thanks for your ideas.
Given that the US 800 is in a somewhat awkward spot and I'm not overly keen on plugging and unplugging cables in case they cause problems with the connections later on, I decided to steal the remote switch that the wife uses (or used) to turn on the Christmas decoration lights.
Something like THIS might work also. Kinda cheesy tho...
You don't want to use something like that, it relies on cutting one of the wires and bayonet inserts - pieces of crap. I've got my US800, reference amp/speakers, Mackie mixer and monitors on a power strip, wire-tied to my mixer desk legs, easy access and out of the way.
