A
Alekisi
Hi everyone!
This is really a informative forum and it took a couple of days to read all the interesting subjects. But I´m still not sure what seems to be problem with my TSR-8 so I need to place some questions. Sorry if my english is clumsy, hope I´ll get the message through.
Just got my first r2r-recorder. I bought it for a fairly low price from Austria, seller said that it had problems with rewind. The deal included 5 pcs of Pyral AF2-tape. I took a risk considering the packaging and shipment over europe, but the machine arrived to Finland in good condition and the seller really seems to know how to pack delicate machinery!
I immediately did two test runs.
First I tested playback with the tape installed and the machine seemed to run well. After a couple of minutes I tested Rewind. As seller said, it didn´t work. The transport clicks to a rewind position but the tape doesn´t move. Then I pushed Forward and it worked until it got to the middle section when the machine slowed down and stopped. At that point even the Play was unstable and hardly kept running. I kept forwarding with manually helping and when I got to the end of the tape I tested Rewind again and this time it worked. Then i took of the reels and tested the transport and everything worked fine.
For second test I recorded 5 minutes of music to all the tracks. Recording worked but during the playback there was a considerable amount of "wow" in the tracks. Also there was a big pile of residue from the tape around the rollers and heads.
First I thought that there was some problems with the motors but after reading all the posts in this forum I came to realise the maybe this is a case of Sticky Shed Syndrome?
But the Pyral-tape is not been listed as a stickyshed-brand so could it be that the tape has a too tight contact with the rollers and it scratched the surface too much?
I took some pictures during the tests and i´ll add them later.
Thanks in advance for the help!
