D
Dantacruz
Hey, I'm new to this forum, but think I'll be around a bit. I've picked up some great info here.. but I'm stumped enough to start my own thread. Any TSR-8 fans out there?
I recently acquired a Tascam TSR-8, that hadn't been fired up in over ten years. I'm excited to get it up and running.
The play function wasn't working, so I opened it up, and found the capstan belt had slid off. As a test, I popped it back up on the wheel, and then the play button worked as it should, until it slid off again.
I replaced the worn out belt today (pat on the freakin' back!) and now when you hit play, the pinch roller clicks up against the capstan as it should, but evidently not firmly enough. If I push the pinch roller with my finger up against the capstan, the play function engages and seem to do it's thing, but stops as soon as I let go.
Before I open it all up again tomorrow, I thought I'd check to see if anyone knows what it might be. The rubber on the pinch roller seems to be in good shape. Is there a spring, or a tension adjustment that needs to be made? I feel like I'm so close!
So, to re-cap.. yes, the capstan is spinning nicely with it's new belt, and the rubber looks good on the pinch roller. They just don't seem to be mashing together hard enough to engage the play function. I'm also using a new reel of RMG tape.
Cheers!
Cheers!
