tascam fw-1082
  • Thread starter Thread starter DesertEase
D
DesertEase
Notorious
anybody know how to sync this thing with flstudio i been tryin to do it for a month now and can't get it.
I'm not sure what you mean by sync. If you have the drivers installed and select it as your I/O device it will be in sync.
I was tired when i first wrote this so i'll explain it more. I got it as my sound interface and my midi interface but i don't know how to get it so i can use the faders and assign channels to the tascam . i can't use the control surface is what i'm saying. i tried the tascam us-428 preset and the transport buttons work but the faders do not. someone told me i need midi codes or sumthin but i can't find them anywhere
search your FL help/manual for controller set up... dont know the prog myself... does it even allow controllers???
I would also check to see if the software supports Mackie HUI or controll surfaces. If it does try to use the Makie Emulation mode within the driver panel.
The Tascam lists FL studio as compatible so no problem there. Just try the other control protocols.
thanks guys i've done most of what you told me i must be overlooking something
Kevin DeSchwazi said:
The Tascam lists FL studio as compatible so no problem there. .
unfortunately as i found out when i tried with my fw1884 and nuendo... to tascam "compatable" is "yeah it could sorta work in theory..."
wut i found out was that i can use the 4 eq. knobs for anything i wish but the faders are not compatable with fl . fl does not support moving faders in any of there software not even version 7 :(
