analogkid
I Bleed Analog!
Sadly I tossed many MANY product brochures from the early 80s..... who knew that advertising junk would be worth money some day?
AK
AK
...there's always at least one...it couldn't be as easy as just pulling the connectors could it?
) its out. I'll inspect for any cold solder joints and make sure all the connector pins are happy lookin'. There is a little PCB called the Delay PCB that is siamesed onto the Control PCB...they are lapped together by a couple test-point pins...seems like an afterthought...anyway both solder joints have broken loose so I'll repair that too.
So it was a good challenge and learning experience. Everything came out fine...I think getting the soldering iron in where it needed to be without frying other stuff was the most tenuous part of it, but everything came out fine.
and applied petroleum jelly to the seals and its got a kick now!
I'd try one more time to suck it out but it was difficult, so I took a push pin to open the hole up. Be careful if you have to do that...the fiberglass PCB's are pretty durable and I found that the Control PCB (and it may be the same with your amp cards...its not with mine, but my 48 has the nicer material for the amp cards) has a really good coating over the traces that is burn resistant and holds the foil on nice, but I'd hate to have to repair a trace on a PCB like that...its just so tight, at least for my skill-level.
: Had to actually take it out the front of the deck...fortunately the arming panel is already loose. Anway, its out and I started removing the old caps last night. I'm about 1/8 done with that part.
Oh well. need 6 more of one type of cap, but lookit how tight this thing is...I know its not like soldering surface-mount chips or anything, but for this guy it was a little bit of a new experience...
The Interface, Control and Fuse PCB's have to be removed or moved out of the way as does the transformer (so you can remove the Interface PCB mount brackets) in order to get it out, and then it is almost impossible to get to the top two of 4 screws that hold the Capstan PCB to its mount...then three of the screws drop down into the cardbay because you can't get your hand in there with the screwdriver tip...it would be a whole lot easier if the deck was on its face. It would be great to do this work with it mounted in the CS-607 rack but the side panels have to be off to remove and reinstall the PSU PCB. I'll have to see if I can find a way to safely block it up when I go to put the Capstan PCB back in. It would be easier to access if the entire transformer shelf was removed but that runs full width...wasn't going there.
Maybe they thought nobody would be stupid enough to pull one anyway...well, that clearly has not stopped me in the past.
...and lots of funky makeshift connections too.
