sweetbeats
Reel deep thoughts...
Silly question for you. So you have positively verified the synchronizer "CAN"T read TC at all with the lifters extended ? You can do that by soloing the recorder and manually holding the lifters out while the tape is fast winding in either direction. The TC should display continuosly.
Do you mean manually retracting the lifters in fast-wind mode?
If the ES-50 tells the 58 to fast-wind, and the lifters extend (push tape away from the heads), the TC stops. If I manually retract the lifters in fast-wind mode, the TC starts up again, jumping to whatever the current position is on tape. Then there's no problem because the ES-50 is reading code. The problem occurs when the ES-50 puts the 58 into fast-wind mode and I don't touch the lifters. The synchronizer stops reading TC, and the 58 keeps right on going until it runs out of tape. The synchronizer never tells it to stop fast-winding. I'm assuming this is because the secondary method by which the ES-50 gets its positional info from the 58, the tach pulses (at least that's the impression I was given), is not functioning right.
I don't truly know what the cause of the problem is
