P
pianodano
Guest
Danny,
Awesome, awesome post. I get it now!
The historical bits are extremely valuable and really, really interesting. Its one of the best parts of these forums.
While my ES-50/51 is a bit antiquated (by virtue of the fact that it does not speak MIDI), I'm really impressed so far with how solid it seems to operate. In other words, the problems that I'm having are not related to a flaky synchronizer, its my setup and lack of knowledge at this point with the gear. I know the ES-50/51 was not built by Tascam, but outsourced. I have no idea who built it, but if Tascam was invested in synchronizer technology, I wouldn't be suprised if they were choosy about their suppliers. The innards of the ES-50 are very impressive. The quality of the PCB's and associated components are a cut above.
I'll keep at it. Your time in explaining things the way you have done is helping me keep my perspective and drive to stick with it.
Your inadvertant reminder to me about the link between Avid and Digidesign explains why their systems provide for successful DAW slave environments.
Grrreat stuff.![]()
Danny,
It is an issue.
You might recall some of our discussion from a year ago or so over at the Tascam Forum that, while you are sending MTC over (duh) MIDI to your MicroLynx to which it is locking your atr via SMPTE from the MS-16, I am sending SMPTE (recorded to a track in the DAW) from the PC over audio, to which the ES-50 is synchronizing the SMPTE from the 58. I think back when we were discussing this you figured it should work, but whether or not it would be frame accurate you didn't know. My tests so far show that I can get the 58 to phase-lock to the DAW with a variance of less than a frame (i.e. about 3 or 4 subframe accuracy over a 15 minute run), and it isn't drifting, just varying over that range.
Now that I've figured out how to jam and restart the sync generator in the ES-50 I *should* be able to record phase identical stripes in the DAW and on the 58 and chase-lock them with the same accuracy. Don't know yet how audio reproduction will sound, and I still need to work through the mechanical issues (58 does a crazy scrub-dance when I command it to locate to different offsets...). I think I'm going to have to try and manually calibrate the settings for the 58 in the ES-50 since the auto-calibration procedure requires two atr's to be connected. It errors out because only the 58 is attached. Once I build my MASTER I/F cable to connect my 48 with the ES-50 in addition to the 58, then I should be able to do a proper auto calibrate procedure, note the settings and then manually set the ES-50 for the 58 when I'm locking the 58 to the DAW.
Sorry...more than you wanted to know...did I answer your question?
I realize I could get a simple SMPTE to MTC converter, but I wanted to see if I could get it to work in a SMPTE exclusive environment first.
Ok. If you decide to eliminate the potential hassles of recording and using a dedicated smpte audio track on the daw, I believe a Midiman Syncman will, 1: accept the input of MTC from any available midi port from the DAW. 2: Automatically pass this thru as translated smpte in 29.97 or whatever frame rate you use. 3: always calculate the correct offset wherever you happen to be on the grid in the DAW.
You can find a Syncman on Ebay for cheap. I just read thru the manual of my Midiman Syncman (PLUS) which I have had many years, and I am fairly confident it will work in your situation.
That MTC to smpte time code it outputs would then be just plugged into the Synchronizer as the MASTER machine. The Synchronizer, when the machines are grouped, should dutifully follow along to this TC and when you stop the DAW, it should stop the ATR imediately AND if you rewind the DAW, always (THIS IS REALLY IMPORTANT), hit transport play (spacebar in Sonar, don't remember what it is in Cubase) for a split second and then hit stop to send the new TC position to the synchronizer . I doubt if Cubase (Sonar sure doesn't) outputs MTC on rewind. Sonar only spits out MTC when the transport is running, if you catch my drift.
Always allow at least 4 or 5 measures at the head of the song to allow subframe lock. You should see, optimally, a 0 subframe error in a measure or 2 but upon start you may see it pull the machine down from say 20 or more subframes over a couple of measures, to 0 error. That's not to say that you can't start playing anywhere in the song, You surely can. You will just need to allow a bit of preroll to resolve and lock the machine. Don't confuse that with preroll in the synchronizer setup. I mean in this case preroll as in if you want to start a punch recording on measure 30 in the DAW while the ATR is locked to it, it would be a good idea to start the daw at maybe measure 25 or 26. Don't forget to develop the habit of ALWAYS HITTING PLAY for a split second and then HIT STOP whenever you rewind the DAW.
BTW, I don't think there is anything at all wrong with your synchronizer choice. Are you sure it doesn't alreay have the 58 transport stored as one of maybe a 100 other machine transport options ?
Keep me posted.
Danny
