cjacek
Analogue Enthusiast
I'd like to offer my own 2cents, if I may...
Cory, the sync head appears to have most of its contour still left, which means very little wear. The erase head also looks good but I don't like the sound of the swab test, where you feel that 'stray fibers of the swab catch' on something 'sharp' [on the erase head]. Still, this does not explain [at least for the most part] the clean running TEAC test tape, so I don't think the erase head issue is at fault here. Also, the sync head doesn't present with an unrealistic oxide shed but even a spec (as seen on a couple of tracks) can present audio issues. I'm also a bit concerned about the amount of oxide (and chunks) present on the pinch roller.
Overall, the erase head and pinch roller present with an unacceptable level and type of shed. How is the playback head?
I feel it's the RMGI tape which is the problem (bad batch).
BTW, you should use those low lint cotton pad makeup removers for cleaning the heads and metal parts of the tape path and lint free cloth for the pinch roller. It's much easier, quicker and more effective than those cotton q-tips. They're fine for a cassette deck but not open reel. Trust me, go for the make up removers!
