Alexwfm2030
Hello,
I'm trying to get this recorder back to work as it doesn't look in too bad condition and the heads seem to have some life left in them. At first it needed a belt change, so now I'm on the sound tests.
Unfortunately I don't have a test or alignment tape, so I've been recording a 440hz sine on all 8 channels at once for a few minutes and listen back. I'm using the recommended tape from the manual, UD-35 (second hand but looks ok)
What I notice is that there is there are spurious interruption of sounds across all 8 channels but especially on 1 and 8. I did take a look close up on the R/P head but it doesn't look worn to the point of explaining this issue. I'll attach an audio file of CH1-8 which then changes to 2-7 after about 25 seconds.. if you were to look at the waveform you could see how it looks more like signal dips, but I'm not sure what is causing them. My initial thought is dust on the tape, but I can't see how that wouldn't be the case all the time. The noise happen at random times on all channels and it can't be heard/seen at the test point just before the bias trap.
--------in the audio file you might hear a break every 8 seconds, it's cause I'm using a sampler which loops a sine. Not the best way to test but it's quite distinguishable from the actual noise which is on continously.
I've tried demagnetising but not with a very fancy demagnetiser.
Attached are also close ups of the R/P and erase head with and without tape. The machine is all plugged in and ready to test if anyone has any ideas on things to check!
tape test.mp31.4 MB
