M
mad flows
hey what would be the best studio monitors that give you alot of bass for 300 dollars
mad flows said:hey what would be the best studio monitors that give you alot of bass for 300 dollars
mshilarious said:For $300 you're looking at monitors with 6" woofers. Those will be weak on bass, causing the resulting mix to be bass heavy. If that's what you want, no worries!
hasbeen said:Alesis Monitor One
mad flows said:
hasbeen said:Those are the active ones. If you don't have an amp, these may be for you. I was referring the passive ones. They are on ebay for a really good price, but you need an amp. Do you have one?
mad flows said:Na i don't have an amp are passive better than active or something?
mshilarious said:For $300 you're looking at monitors with 6" woofers. Those will be weak on bass, causing the resulting mix to be bass heavy...
packratlouie said:Well I'm not sure you can say this, coming from a limited point of a view. Every single speaker has a full range of frequencies, within 20Hz of the low end. Saying that since you dont have a speaker that shows the low end at a higher amplitude, that your resulting mix will be bass heavy is ONLY true if you dont know your monitors.
me said:if your monitors give you a big bass boost, and you mix to taste based on that,
