Sounds good when i record it but in iTunes the BASS is high as fuck, what to do?
  • Thread starter Thread starter MkII
M
MkII
I don't know if the title explains all.
Anyway.
I've recorded a tune in garageband, it sounds nice but when i export it from garageband i sounded weird, missed tunes here and there.
Problem solved: by "soundflowerbed" --> play the song in garageband and record it in audacity! results is good. everything sounds fair but after i export it and play it in iTunes the bass is so loud that it only generate "crack sounds" like when u play more bass then ur speakers normally could handle. Every other songs i've not recorded myself sounds really nice i iTunes.
Any ideas of why i have bass/low freq sounds problem in "only" iTunes with my own songs ?
Using a Yamaha MM6 as a midi synth if it matters
// Jesper
I'd say it boils down to the monitors you mix thru and the room you mix in.
Erm. Do you have the iTunes EQ set to "bass booster?"
Command+Shift+2 should bring up the Equalizer for iTunes, or go to View -> Show Equalizer. If that's anything but flat, I found out what your problem is.
it was on rock. it sounds better with flat but still some "crackling" sound.
When i play this song with my regular speakers the low freq is pretty much higher still. the room vibrates a bit in comparison to a power metal tune etc. but it's acceptable.
thanks a lot!
Any iTunes related question can be answered universally with this high quality piece of advice: Don't use iTunes.
Monkey Allen
Replies
190
Views
26K
Monkey Allen
Monkey Allen
I
Replies
232
Views
18K
grimtraveller
grimtraveller
Monkey Allen
Replies
39
Views
3K
Monkey Allen
Monkey Allen
