D
DGChaos
I have Sony Acid Pro 7 and Guitar Rig 4. I'm currently using a BehringerUCG102 Guitar Interface.
When I open up guitar rig and use the effects normally with my interface, it works pretty well. No problems there.
But when try to record, there's some trouble.
In Sony Acid, I tried using the Guitar Rig 4 vst. Under "audio device" in the Sony Acid preferences, it says Behringer USB so I get the output from the interface.
Even though the stuff sounds great with Guitar Rig 4 alone, it sounds atrocious after I record it on Acid. On top of that, when I remove the plug-in, even the clean sounds are pretty distorted. After tweaking around with line 1/2 in/out I can get decent clean sounds but then there's always a high frequency sound at the back.
Hence, I'd like to know if there's any way I could record WITH the effects. The effects have to be part of the track and should work even without the plug-in. That is, I just want the sweet sounds I hear on my headphones via Guitar Rig 4 and my interface as one complete Acid track.
Any ideas? Thanks for your patience.
