H
Henri Devill
Racked API and Neve mic pres...LA2A..Leveling amp...
Don
Don
Blue Bear Sound said:Which is EXACTLY the same proximity effect you get with the 58.......
same capsule, same polar specs.........
Next your gonna hear ,
analog all the way...
ALBERTPIKE said:Directly from the Shure website:
It is true the SM57 and SM58 microphones are based on the same cartridge design. The main difference between them is in the grille design. The SM58 was designed for vocal application and it uses a separate grille with a very effective pop filter. The SM57 was designed as an instrument microphone where smaller grille size is preferred. In this application the pop and wind are not usually a concern. The SM57 uses an integral resonator/grille assembly, where grille is actually a part of the cartridge. These two grille designs place the diaphragm of the microphones in a different acoustical environment. First of all, the distance from the top of the grille to the diaphragm is significantly shorter on the SM57 compared to that of the SM58. This allows for closer sound pickup with even more pronounced proximity effect. Secondly, a different resonator/grille assembly design of the SM57 is responsible for its slightly higher output above 5 kHz.
www.shure.com
...I'd take a Beyer M69 over a 58 for live vocals anyday!juvenal.floyd said:Re: SM-57 vs SM-58. Which one?
Blue Bear Sound said:But then, that's pretty much the same as a 58 then!
Have you ever compared the 2 with your own voice, Crawdad - to see exactly what the difference may be? (serious question - no sarcasm intended...!)
Giganova said:For SAX recording I wouldn't recommend these mics at all! They will sound very tinny (I've tried them with my tenor sax). Go for a large condensor (expensive, though), the AKG C1000, Sennheiser 421 or 441, or the Neumann 184. These mics are great for recording sax!
