P
paperhatrecords
paperhat
I bought a Tascam 38 Reel-To-Reel recorder about a year ago, and after a lot of fixups finally got it working. The problem is that the Ramsa mixing board I got with the reel-to-reel sounds like crap - doesn't have any headroom, so everything sounds muffled and weak. My next question is what sort of mixing board should I get that would ideally meet the following specifications:
- analog (although if there is additional digital effects processing that can be turned off without interfering with the signal I wouldn't mind the bonus)
- minimum 8 separate channels, obviously
- direct out and tape in for each channel
- would prefer if the at least the mic and line inputs were on top instead of in the back for easier access/maneuverability
- good quality, nice preamps, plenty of headroom.
- < $500
Does such a mixer exist? I've searched around and there aren't many new mixing boards anymore that have direct outs per channel, as most people have gone digital; I don't mind buying an older board at all as long as it's quality.
I've noticed the many good things said about the M-300 series, but I still wish the line/mic inputs were on top instead of in back, beneath all the RCA jacks. I record solo, so I'm probably not going to be using more than 2 channels at once, and thus would be moving the mic or line around alot and would prefer not to crawl around below a tangle of wires... That of course, is a minor requirement compared to getting the best quality, so I'd work around it if it is a worthwhile mixer.
Alright, thanks in advance...
- < $500
