			miroslav
Cosmic Cowboy
For you, is recapping mostly preventative maintenance for future problems, or fixing a known problem?
I saw some QC labels on the strips marked '90...so I assume that's when they were assembled and put in the console.
So it's a 26 year old console...the old caps were most likely well out of spec...they don't last forever.
The problem is...you don't notice it easily when you just use a console, as your ears slowly adjust the degradation, and you forget what it sounded like when you bought it new. So you have to compare a channel with old caps against one with new to hear the difference.
While I heard no problems with them...when I finished recapping, it was pretty obvious. The console came to life, the sound is open and crisp, the low end tight and punchy. I'm sure the change in in chips also adds to that, as I did compare channels with the original stock chips and the upgraded ones...and it was noticeable.
Plus...rechipping without doing the recap would be kinda dumb...especially since the new chips would run the caps harder.
Sorta like putting new tires on a car, but not replacing the worn out ball joints and old brakes.
So it was kind of preventative...but really, it was more about getting it back to spec, and better, since it was most likely already out of spec with the old caps.
The new caps are high temp caps, and they will last longer without degrading...and hold up better to the demands of the new chips. The console will now be at good to go for at least another 25 years.
