M
M3TA1
When I record vocals, I get background noise. I don't have the space or money to buy those acoustic panels so is there a way I can eliminate background noise without spending too much?
What kind of background noise? The sound of the room? Hum or hiss from the equipment?
If you move away, you change the tone, so you either adjust the gain for the loudest section, or record the track in two sections. Moving is bad.
My mic picks up small sounds like my fan from my computer. Unfortunately, I don't' have the space or money to make a vocal booth. I want to get the best results I possibly can with the gear I already have. If I keep the gain low on my interface and I get closer to the mic, it helps a bit and when I enable compression and noise gate through Logic it helps.
