B
borriffick
I'm using the PreSonus FP10 for live recording. So everything goes in the inputs, and then from the outputs on the back to the PA.
All of the inputs seem to work just fine (everything records perfectly). The problem is between the outputs on the back of the unit to the PA. There is a low humming sound that comes from the PA as soon as I plug something in back there. I've tried all different combos of cables, two different PAs in two different venues as well. Does anyone know if there are any known issues like this? I can't find much about the output hum, only some people reporting a hum with the inputs which isn't my issue.
Thanks so much!
Thanks so much!
