Post Your Dream Guitars Here
  • Thread starter Thread starter ido1957
"sob..." "drool" :(
will probably remain a dream.....
Nope, nothing to do with intonation. I don't know if Ralph says it is or not, but it doesn't do a thing for intonation. It DOES, however, make the guitar a lot more ergonomic to play. It also has some effect on the tone of the individual strings, in that it can make your low strings a bit tighter sounding (as they are at a higher tension), which can be a good thing for some people. But the real advantage of it is strictly ergonomic. The slant to the frets makes stretches and barre chords less stressful on your hands. I made a guitar with them, and it's really nice. It looks like it would take a while to learn to play it, but I found the learning curve to be very shallow.
Light
"Cowards can never be moral."
M.K. Gandhi
I'm probably wrong here, and I'm asking mostly to see if you can shed some light on this, but I thought there was an indirect impact in intonation?
I mean, my understanding is that the longer the scale length, the easier it becomes to intonate lower pitches - the lower you were tuning, the further back you had to get the saddle to intonate correctly? This is certainly a probelm in the seven string communty, for people tuning seriously low (like, Meshuggah territory).
To be fair, this could also be due to the heavier string guages people typically use as they tune down that low, so it could be less tuning to F below E standard and more the fact you've got an 85 on your guitar in an attempt to preserve tension, lol. If that is in fact the case, then a multi-scale neck makes it easier to intonate for low tunings by simply keeping string tension higher so you can bypass that entire can of worms.
One guitar that I'd LOVE to own is a National Resophonic
http://elderly.com/new_instruments/items/NGRL3.htm.
Otherwise, I've pretty much got one of my dream guitars in my Gibson Les Paul Faded Double Cutaway (Worn Cherry) - http://www.musiciansfriend.com/prod...517512&src=3WFRWXX&ZYXSEM=0&CAWELAID=26043754 - and I have a used Gibson Les Paul Junior (Cinnamon) - http://www.musiciansfriend.com/prod...517324&src=3WFRWXX&ZYXSEM=0&CAWELAID=32767377 - on lay-away (just one payment left!). I'll add a Bigsby B5 vibrato to both Les Pauls. On the LP FDC, I'll replace the 3-position toggle switch with a 5-position rotary switch, and wire it - 1) bridge; 2) bridge-neck series; 3) bridge-neck parallel; 4) bridge-neck out of phase; 5) neck. The LP Jr. will get the 3-position toggle from the FDC, and will get wired similar to a Fender Esquire. With the "slight" re-wire jobs, and the additions of a Bigsbys to each, both guitars will have exactly what I want in a guitar. The FDC will be used mostly for rhythm, and some leads, and the Jr. will be used for leads.
Matt
My dream guitar--I'll probably never have enough disposable money to purchase one, but it's nice to dream about it.
MY DREAM GUITAR....
is a reality.
my USACG strat project
(full pic)
(headshot)
(side headshot)
(jackplate)
(bill lawrence pickups, and the hipshot trem)
(backshot)
body: lightweight Alder 2-piece, with a contoured heel, routed for a 2-post
Hipshot trem, non locking, side jack, fall-away cut out on the back side of the bottom bout.
pickups: humbucker-single-single, Bill Lawrence L-500L and 2-280s (n & m)
Q filter for the L-500L wired to 'tone pot', and a master volume.
neck: hardrock maple neck, with a pau ferro fingerboard. 6150 frets, 1-5/8" nut width. small fender-style headstock
Gibson scale length neck, 22 frets, fingerboard radius, of 12". the shape of the neck is a thin "C" shape,
with a .78" neck thickness at the 1st fret, up to .85 at the 13th, mother of pearl dot inlays.
headstock: tiltback design, 13 degrees, graphtech nut.
Not that I've noticed.
Light
M.K. Gandhi
Light,
You're correct about playing the slant fret beasties. I had the opportunity to play one made by Jim Williams some years ago and the best thing to do is NOT LOOK at the fretboard as you play, your fingers then almost naturally fall into the correct positions ;).
:cool:
I'd also like a Paul Reid Smith like the one the guy from cradle of filth has
[/IMG]
that's my dream guitar, and i've had her for 2 years :)
Thats still a beauty and I'm still glad you didn't refinish her.:)
ya she's a beauty isn't she? i guess if i'm going to want a violet burst i'll have to find one second hand somewhere cause they've been discontinued.
