J
Jzoha18
Member
I bit the bullet and looked at the jacks themselves and this is what i see. Im assuming that red wire to pin 2 is the ground? what do you think?
Let’s try to solve one thing at a time. There’s a difference between phase and polarity and it would help if you provided some specific reference to what it is you read.I should also mention that i am using an original mackie CR1604. which i have read is also wired out of phase for its outputs. Will this contribute to anything even after the otari pin config is solved?
yes its a TS plug>RCA on a channel access jack with an XLR on the other endWaaaaait…backup…you’re using the insert points on the Mackie? So you have the TS adapter plugged into the first click to use the insert point as a direct out, and that’s connected to the mono price XLR - RCA cable to the input of the Otari?
Looks like we figured out the config on the otari. sorry i am being such a headache. do you think perhaps i should swap pins on one of the XLR inputs and see what happens?And no, red wire to pin 2 is not ground. Pin 1 is ground, pin 2, according to your meter reading is not connected at the other end, pin 3 is signal.
No. Last thing you want to do when you’re having trouble figuring things out is take shots in the dark hoping it will work. And we already figured out the configuration with your meter. That’s why we went through all that…your meter told us pin 2 n/c (not connected), pin 3 signal. So unbalanced pin 3 hot. Pulling the jack only tells us three wires are connected.Looks like we figured out the config on the otari. sorry i am being such a headache. do you think perhaps i should swap pins on one of the XLR inputs and see what happens?
its this cable with a RCA to TS adapter if im not making sense
Monoprice 6ft Premier Series XLR Male to RCA Male Cable, 16AWG (Gold Plated) - Monoprice.com
An XLR to RCA cable converts a balanced audio signal into an unbalanced signal. This is good for sending audio signals from an XLR source to an RCA input, or vice versa. Regardless of direction, the rwww.monoprice.com
So, #1, answer this question: are you inserting the TS - RCA adapter into the channel access jack all the way, or only to the first click?yes its a TS plug>RCA on a channel access jack with an XLR on the other end
The TS is inserted on first click and its a setup that works with all my other multitrack decks. so the cable is incompatible with the deck as its configured? if i simply switched the decks pinout would the monorpice cables work? based on what you saw?
And #2 remind me what you learned when you probed the monoprice cable to determine what pin of the XLR jack the pin of the RCA plug is connected?
[EDIT]
Okay…dude! I figured you already knew or checked into the pin out of the monoprice cable…look at the description of the cable you bought on the website…it says “This cable uses the standard pinout with pins 1 and 3 of the XLR connector wired to the shield of the RCA plug and pin 2 of the XLR connector wired to the tip of the RCA plug.”
So think about that for a minute, and what your meter told you the pinout configuration of the Otari is, and there’s your answer about why it isn’t working.
Yea the pinout is swapped so the ground of the otari is feeding the tip of the rca and ts and thats why its defeating the signal on the mixer correct?
[EDIT]
Kind of. There’s no pinout swap going on here. The monoprice cable shunts the signal to ground. It doesn’t mean it’s a stupid cable. The cable is configured one of the typical ways a cable like that (that connects a balanced device to an unbalanced device) is configured. And the Otari is configured in one of two common configurations for balanced XLR I/O.Yea the pinout is swapped so the ground of the otari is feeding the tip of the rca and ts and thats why its defeating the signal on the mixer correct?
should mention that the otari is using unbalanced XLR and the manual makes descriptions of jumpering pin 2 to pin 1 if that matters. i would rather just modify the otari so if a cable goes dead on me i dont have to build one and i think its smarter and easier labor than building or modifying cables. i tried the hosa phase reverser adpater but it didnt work. im assuming because its primarily designed for phase reversal? thats what it says its for. its this one. why do you think it didnt work?Kind of. There’s no pinout swap going on here. The monoprice cable shunts the signal to ground. It doesn’t mean it’s a stupid cable. The cable is configured one of the typical ways a cable like that (that connects a balanced device to an unbalanced device) is configured. And the Otari is configured in one of two common configurations for balanced XLR I/O.
Here’s what’s happening:
There are two common balanced XLR pinouts:
pin 1 ground
pin 2 inverted phase signal
pin 3 normal phase signal
That one ^^^ is “pin 3 hot”. it is less common, but common enough in older gear you have to watch for it.
Then there is the most common configuration:
pin 1 ground
pin 2 normal phase signal
pin 3 inverted phase signal
…”pin 2 hot”
So your Otari is pin 3 hot, and *also* doesn’t have the signal balancing kit installed so pin 2 is not connected, at least according to your measurements.
So you’ve got:
pin 1 ground
pin 3 signal
Now let’s look at your cable. It’s configured assuming pin 2 of the XLR is hot, and so pin 1 and pin 3 of the XLR end are strapped together and connected to the shield of he RCA plug, while pin 2 carries the signal to the pin of the RCA plug, and ultimately the “tip” of your TS adapter; all good, except that with your Otari pinout, pin 2 is not connected, so your cable carries no signal to the RCA pin, and furthermore your signal is on pin 3 which is connected to what? Pin 1 in the cable, ground…the signal is “shunted” to ground. Double jeopardy. So you can either buy an XLR - XLR adapter that swaps pins 2 & 3 of the XLR, or do it at the Otari jacks and swap the connections at pins 2 & 3, and it should work.
You can test all this if you have some hookup wire and a TS -TS cable…cut two lengths of wire, strip the ends, shove the end of one wire into the pin 1 socket of an XLR input jack on the Otari, and wrap the other end around the shield portion of the TS plug, shove the other wire into the pin 3 socket of the same XLR input jack and wrap the other end of that wire around the tip of the TS plug, and then plug the other end of the TS - TS cable into the ACCESS jack of your Mackie. Signal should pass.
i
should mention that the otari is using unbalanced XLR and the manual makes descriptions of jumpering pin 2 to pin 1 if that matters. i would rather just modify the otari so if a cable goes dead on me i dont have to build one and i think its smarter and easier labor than building or modifying cables. i tried the hosa phase reverser adpater but it didnt work. im assuming because its not flipping polarity
my deck is a mx5050bqii which is a different model then the Bii and the manual for it says unbalanced. Ill re paste what the manual says belowSo the MX-5050BII manual I have indicates your inputs and outputs on the Otari are balanced. So I’m not sure what to make of your meter measurements that indicate pin 2 of the XLR is not connected.
I think you need to do the hookup wire test to check out what’s happening with pin 2 and pin 3.
id also like to thank you for helping me trouble shoot this so far!So the MX-5050BII manual I have indicates your inputs and outputs on the Otari are balanced. So I’m not sure what to make of your meter measurements that indicate pin 2 of the XLR is not connected.
