Orthophonic High Fidelity
  • Thread starter Thread starter whyseye
same test between pins 7 and 8. - :cool:
now test on tube tester.
Note: "G" (grid) set to "2" and "K" (cathode) is set to 3 - test between pins 2 and 3 - indicates "SHORT" - indicator lamp glows.
Actually the way it happens is this. When you insert the tube into the socket - at first there's no short indication , but as the heater warms up - the neon lamp indicator starts blinking and then it gets brighter and then glows continiously.
same situation with the "other side" of the tube - pins 7 and 8.
Well, thus this tube is not "qualified" for any farther testing and must be discarded... , or placed into collection of bad tubes :p :D
As far as "emission" goes - that is another story.
Basically - bad emission - bad tube, good emission - good tube. Right? Well, maybe so, but I am not sure about it.
In general, the problem is that if you see a nicely glowing tube it does not mean that it is a good tube. Also a tube that is tested "BAD" for emission is not necessarily is useless or flat out bad. I have for example a tube that I've tested "BAD" for emission. A nice looking british 7025 tube. So, I've said: "Sh*t! Arghhh - to damn bad." SAnd then I've tried it in one of my guitar amps in preamp section, and it actually worked just fine. Maybe not so good for a lab test or for some application, but I could rockin'roll with it pretty damn well. :confused: :D
I've read that "good emission" does not mean that the tube is good, but I have never had such experience, or maybe it's because I just do not have high demands on a tube performance.
Also, I think it would be worthy to mention here. I think, when dealing with any old tube piece of gear - the tubes most likely are fine in there and if it does not work right, then the problems are most likely somewhere else. I maybe wrong on that one, though, but I have been successful in the past in scoring great tubes by purchasing old non-working DOA gear for cheap :D :p - that is the trick, well, sort of .
here's that tube, tested BAD, but it rocks - so go figure.
I gotta learn to spell
Wil816 said:
I haven't heard of loss of vacuum. The silvering is from the the internal elements essentially being distilled onto the inside of the glass. It happens with light bulbs as well. If air get in though, the glowing parts (at least the ends of the heater filament) will burn and smoke.
THat silver is called the "getter" and is typically a metal like barium. It is silver when on the glass and will quickly oxidize to a white color if the envelope leaks and lets oxygen in.
http://en.wikipedia.org/wiki/Getter
BTW... would you guy's do me a favor and learn the diff between a short and an open... :p :p :p
a short implys a lack of resistance.....
an open is total resistence....
and we know resistence is futile....
transistors generally short
resistors open
diodes short
caps short
inductors can do either but ultimately open
think of it a fuse which shorted would'nt be any protection at all.... :eek:
:eek:
the favor is done.
resistors open
diodes short
caps short
now, what are YOU going to do about it? :D
