L
l_tunaboy
I'm new to the forums (and analogue recording) and have just acquired a Tascam 388 for very cheap. I've tested the mixer and everything works, but the transport controls do not.
When any control is pressed (FF, RW, Play) it will play for a second, and then stops. It seemed like similar problems others had was do to a fuse, but the continuity checked out OK on all of mine. The capstan belt is also intact and the shaft is rotating fine. I've also cleaning the tape path.
What I've just noticed is something odd. On the shaft that holds the left reel in place, the three tabs on the bottom of the shaft are missing. It seems almost like someone broke them off, as all three of them are completely gone. The right reel holder has them all intact.
I was wondering if this would cause the reel to not catch or something and be what is causing the abrupt stopping after the play button is pressed.
Thanks.
Thanks.
