No Midi signal to Tascam us-122
  • Thread starter Thread starter stephax
stephax
Hey, I'm pretty new to all this and I have a problem.
I want to use the midi signal of a MicroKorg through my Tascam us-122 to go into FL Studio. The MicroKorg is switched to Midi and a midi cable is going from Midi Out into the Midi in of the tascam. Tascam and laptop are connected, the driver is installed and tascam recognised and switched on in FL Studio. Everything looks right in FL Studio, so I think the problem is with the Tascam. Since the Tascam has got a little midi-in-lamp I thought this should be on as soon as a midi-connection is set up...but it doesn't blink. Can you please help me?
Many thanx
Stephax
download midiOX (free). It has diagnostic tools which will help you determine where the issue is. Make the connections and check the monitor to see if the Korg is or is not sending data (I suspect it is and you cave a config issue with FL)
thanx for teh quick reply...I'll give that a try. though: If the Korg is sending data, shouldn't the midi in control light of the tascam be on?
