no .. the triton doesnt have phatom power on board... I use the mackies xlr's and I use the insert effect jack out on the mackie 1402 to the 1/4" inserts of the triton. I have presets loaded in the triton in EXB A,b,c ... etc for effects for the guitars.. Like one preset in for rythm guitar.. one for lead.. each using a little or less of each effect.
Someone asked me if they should get a triton to get my guitar sounds... I told them NO! Im just using the reverb and some delay.. you can get these same effects in $60 units.
You also really have to watch your effects chain because there are a few points in the signal chain on the triton where the signal can get flopped from right to left. Thats really way I'd just like a dedicated reverb/dealy unit.. less chain anaylizing.
Each time you go through a electronic device esp. with long cables.. your signal will be transformed in some way. So I loose the natural sound of the
acoustic guitar when I run through the triton with 50 feet of cable going in and out of it
ok... enough rambling.. back to recording
Oh yeah.. about mix control.. I do lose that when I record effects to track.. you really have to get it right the first time..
It would be cool if you could trigger your sounds from the triton along with the insert and master effects on board.. that would really add a ton with giving the drums a nicer sound
Thanks a bunch for all the ears guys!
