Middleman
Professional Amateur
Well I have put a few hours on the Portico and as curiosity was running in several threads, I thought I would put my thoughts here.
I had the DMP3, Voicemaster Pro, Great River 1NV along with the Portico at my disposal. I used an NTK mic into all units and recorded the results. I have to say up front I messed up the test because I used a resonator on one track which covers up the vocal somewhat. This was the Great River track. This preamp was on rental and I returned it so I could not go back and redo the vocal alone. Thus, I won't post the tracks because frankly all things need to be a little more controlled. That said, if anyone is curious about comparing something you own with the Portico, ping me. I kept the files.
My other wish is that I had not used the NTK because frankly, it is a very colored mic and can make even the inexpensive DMP3 sound really good. It tends to color so much that you get caught up in its sound and for these tests minimized the differences which a non-tube mic would not have done.
Impressions:
The Portico definitely has the high end preamp sound similar to the Neve 1073 I have used on occasion. The primary similarity is the rich low-mid quality and the fine precision on the high end. Two channels of this preamp for the $1500 approx. it costs, is extremely cost effective.
The basic sound is remarkable in its smoothness. There is a highpass button and control knob which ranges from 20 to 250 Hz. Phantom power, mute and buss routing buttons are included. If you decide to use the Portico Quad buss module you can later build the preamps into a full scale mixer.
The box is very heavy, full of iron although I have not popped the hood yet to look inside. It weighs more than a Great River and about the same as a Neve 1084 I held this last week.
Quality is high but one of the pots moves a little like someone forgot to tighten the nut to seat it against the case. This bears later examination.
Comparison:
Great River - Interestingly enough, if you use the Silk button on the Portico it sounds very similar to the Great River, almost the same sonic signature. If you disable the Silk button the preamp is more colored so there is some kind of mid range scoop going on with the Silk button. The high end gets more open in the Silk mode, once again, very similar to the Great River.
I actually liked the non-silk mode better, very rich and detailed but not as transparent. This had a great ballad sound, up close and smooth. Who needs compression? (I did run the signal through a UAD LA2A and wow!)
Voicemaster Pro - This was my go-to preamp for a long time but unfortunately it just doesn't have the detail and richness of the Portico. I would say it's about 10-15% less detailed and rich than even the Great River. However there is about a 50% difference in cost so for the budget minded its still a good value.
DMP3- Simply stated, this is an amazing little preamp. I'm not going to say it came close to the Great River or Portico but it rivaled the Voicemaster Pro and was actually a bit richer on the low end. This just turns out to be a really good match for the NTK. I can say that other mics have responded better to the Voicemaster Pro. The AT4033 comes to mind.
Back to the Portico:
It's not going back, I will say that, and my days of renting the Great River and Neve 1073 are over. I need about 3 more of these, someday when I am rich. I think this is a real winner for those wanting to move up in preamps. It has a very colored and non-colored mode depending on the silk button. It may be out of the price range of beginners but for those looking for a high end sound for the least amount of money; this is a short ticket to a professional sound.
MM
Impressions:
Comparison:
MM
