Phil it looks like a pretty clean break at the scarf joint which is the best place it could have possibly broke and also tells me that the join was probably defective to begin with because the joint should be stronger than the wood itself if joined properly. Not real sure about the fret board though. probably better off replacing that and the truss rod seems to be unharmed but hard to tell without actually looking it over.
Now that you mention it, if you look at the 4th picture (last one in the first
pic post), you can see the almost perfectly rounded break at the back of the
neck. Before it was broken, they already looked like two separate pieces of
wood, and it broke perfectly on the "border".
Since I have the guitar here, I wish I could look it over and give you all the
details you need. But I haven't a clue about guitars. I've been playing them
for years, and I'm pretty decent, but I don't know squat about the construction
of em
Thing about fretboard breaks like that is that they are easy to fix. It's gone right on a fret slot so if you can get the neck back without having to piece it in anywhere it's relatively easy to just pop the board back on, rip out the frets back to the nut, in this case two or three frets and replace them after leveling the board. Even putting a false board on between a few frets is fairly easy.
The risk on jobs like that is what is unseen and what you can't tell from the pictures. The crucial bit is getting the neck back clean. The fingerboard is an easy dodge. A lot of the time spent would be in getting the finish right and if philbagg ain't too picky there it's not a problem. I'd be happy to take a go at it if he accepts the postal and time involved. I'd just need some free bench time a few similar jobs in the system and I'm sure I could work it through.
I'm not picky at all
This is what the guitar looks like anyway:
It's not easy on everyones eyes anyway
As long as the neck is back in good shape, and there's no intonation problems
along with it, I'm more than happy
Now, as you pointed out, the break on the fretboard is on a fret bar, directly
between the 2nd and 3rd fret. The bar is now long gone. Is that a problem
or can it be replaced?
I'll very happily take you up on your offer Mutt as soon as I raise some funds,
unless I somehow find an amazing deal here in Dublin where everybody is
more than generous
Thanks guys
