Naked V67G
  • Thread starter Thread starter PhilGood
Innovations said:
Send it to MXL as a suggestion. It really makes a lot of sense. Why hide real brass with paint?
I might actually drive over there and show it to them. They're only about 5 miles from where I live. I've talked with Scott several times, although I don't know if he is still there.
To tell the truth, I'd much rather deal with Brent Casey. Last time I talked with Scott about a broken mic I got pushed off on someone else. Brent's got more class! I think he actually started Marshall and then went to SP.
60's guy said:
Phil,
That mic looks awesome! I just picked up a V67 myself. When you say "Royer modded", what exactly is involved in the modification?
I removed the original electronics and replaced it with a tube circuit designed by David Royer. I also replaced the capsule with one from an MXL 2003. It's a 797 capsule, so the mic sounds fantastic!
If you do a google search with the words "mic", "berlin" and "barstow", you should find the article that describes what it is.
Thank you, sir!
Appreciate the info. :)
That does look great! :eek:
Keep in mind that brass tarnishes pretty easily. Especially if it's handled a lot by hands.
It'll be higher maintenance. That's probably why most brass mics are painted.
Maybe it can be clear coated with an enamel or something?
Right! It's laquered.
See first post. :)
PhilGood said:
I was thinking about putting it on a chain and hanging it around my neck! :D
Ive already done it and it looks great - here's a pic!!
Thanks for the idea!!
does it sound better now? probably just like a Lawson , huh?
Just checked out my V63m..........Its brass. I might steel wool off the paint over the weekend.
I decided I liked it so much, I'm going to do my other one the same.
Twin gold tube mics.
I'm pimpin' out my mics, dammit!!!!!!!!! :D :D :D
Now if I can just gold plate the power supplies and get gold neutric connectors!!
