kensington
hi, Anybody know if and how one could sync a TSR8 to a DAW to a drum machine? Right now I stripe track 8 for syncing a Roland R8 drum machine.
If I put a digital multitrack running off the striped track, can I somehow "chain" other sequencers to the DAW? I need to sync TWO things to the TSR8. If the DAW is set to slave......how can it be set to master the additional drum machine? I's confooosed. Anybody got any ideas or answers?
I'm sure more than one sequencer can be fed off the TSR8 stripe. Some sort of splitter? Magic black box? Can any stand-alone DAW recieve midi info as well as transmit it at the same time....do they all? The Set Up:
TSR8 >>>>>>Roland VS880 (for example)>>>>>>>Roland R8
Does midi "thru" figure into this? As you can see, I'm not very midi-savvy.
Thanks for any info. Kenton
