starsxandxslits
my 3rd efford at mixing on my own...give it a shot and let me know what you guys think. the newest is getting out of dodge.
come on! someone else has to have something to say.. shiould i keep forging ahead, or give up now?
We are having trouble finding your song.
hahahahaha. oh. man. no one on this forum will ever let me live this down...
Oh don't worry, we've all done that at least once. How about it guys? Come on, tell the truth.
Anyway...you've done a fine job overall. I would suggest only a few minor things.
Some of the tracks could use more mid or high frequency presence. Perhaps the toms, snare, and vocals. (But be careful with the S'es on the vocals. Compression tends to exaggerate those.) (Also mids will make the toms sound louder. They don't really need to be any louder, just brighter.)
The only other thing I've noticed was panning. It sort of sounds like everything is in the center.
...and how, besides using a deesser, and being judicious with eq can i get more presence in the vox without a sibilance fest? i have tried everything and it seems like, when i just need it 1 db brighter, i can't push it anymore without ssssssssstt...
You can "notch" those ssssses out of there. (Hint: They are usually most present at around 4000 to 7000 Hz.) One way to pinpoint the offensive frequency range is to push up one EQ slider at a time (with the track on solo) and listen for the sound to get worse. Usually one or two of them in particular will cause that sound to scream out with ugliness. Once you have found it, then pull that frequency down as needed to notch or carve it out of the track.
If you use an EQ that enables you to change the Q setting, you can make more accurate notches. (In case you didn't know, Q sets how wide the EQ bump or notch should be.) You should try to keep the notch narrow so it doesn't suck the life out of the track.
Once the offending frequency has been notched out you are free to bump up other frequencies to give the track the air it needs.
