D
Deleted member 196982
Guest
Well, obviously not a lot of Logic Pro users here, but besides the addition/expansion of their "players" for drums, keys and bass in the latest version, there's a "Stem Splitter" feature that's kind of interesting. NB: This feature requires Macs with Apple Silicon - it will be disabled on Intel-based systems.
At first, I was wondering what I might ever use it for, but on another forum someone mentioned that it had been used to fix some bleed problems. I don't know if "fix" was the word used, but often that's the case. So, I tried it on a mix I did (video posted in MP3 sub-forum). Just a simple 2 guitars + vocal, 3 mics, and a little bit of everything everywhere. I took the same Logic Project, did the stem-splitting on each original track, splitting Vocal and Other (bass and drums are the other specific things you can try). This results in track stacks (a submix thing in Logic) with your stems, and in the guitar ones I muted the vocal stem, and in the vocal stack I muted the "other" stem. I.e., I removed the obvious bleed. I had to apply pan and reverb send to the stack (submix) tracks, though I probably could pull the stems out, those items in the original tracks were not carried over. Volume automation on the original tracks was carried over. And, I had to lower the threshold on the Ozone Maximizer on the stems mix because some [bleed] content was now removed/muted, but just about 0.2dB to lift the stems mix up to the same LUFS as the original. Here are the two mixes - see what you think. (I didn't label them, so picking the stems mix is up to you, but might be pretty obvious.)
on.soundcloud.com
on.soundcloud.com
p.s. (edit) Does this subforum really need to have "Emagic" in its name? I mean, who uses that? Wouldn't GarageBand, now running on Logic's core, be a better fit, in case someone stumbles into this forum to ask a recording question...
SoundCloud - Hear the world’s sounds
Explore the largest community of artists, bands, podcasters and creators of music & audio
