TalismanRich
Charlie, have you called any of the local studios in Tulsa to see if they would work with you? You don't need a big studio, maybe a small independent one might have an ADAT machine that can transfer the individual tracks from the ADAT tape to a flash drive or CD. You don't want a final mix, you just want the individual tracks.
I see some 15 or more studios in the Tulsa area. People like this: AMR Studios - 918-732-9180
I would call the place, ask if he has the ability to transfer ADAT tracks to a different format. If he doesn't maybe he knows someone else in the Tulsa area who has the equipment.
It's not that complicated of a process. If you have the ADAT machine, you either run from the optical output on the back to an interface, like Rob described, or you could run the 8 analog outputs to 8 inputs on the interface. An interface is just a box that lets you bring multiple audio signals into a computer. You said you have a gaming computer. You can run a program like Reaper and simply transfer all 8 channels at one time if you have an interface like the Behringer 1820,
Once it the computer, you save the individual tracks as wave files. Then you can copy/redo/remix/rerecord as much as you like and never lose the original transfer.
