You need some harder questions, Ed's gonna knock those right off.
see how I do:
"1. Have you ever patched
an Arp 2600? "
I've recorded avatars before, is that an ARP ?
"2. Can you tell me the difference between the 2500 and 2600 as far as patching? "
not so sure what synth knowledge has to do with this, tho I could be wrong about the ARP you're talking about being a synth
"3. Have you ever recorded a Minimoog? "
I wish...I've seen one in New York, while I was modding
a Neve 8108 ( dont kill me, the 8108's what the guy wanted and it DID have a cool new bussing system! )
4. Have you ever aligned a 2" multitrack?
Yes, at the beginning of every session that was using analog, and then wrote down any deviations at the end, the very day the tape was to go to mastering
"5. Have you ever switched headstacks on a multitrack? "
Many many, made some money during the 90's changing Studer 827 16 tracks to 24 track. Also replaced a lot of things with JRF headstacks, also set up the 2" 8 track headstack for crazy Jazz nuts
"6. Have you ever sync'd two analog multi's together? "
Too many times to remember, also synched analog to Pro_Digi and DASH recorders as well as all the MDM's, and/or had em chase computers. This is no big deal and I suspect the tech crazy new generation would have even less trouble with this than we did, so what
"7. Can you tell me the freq. of a slate tone and where it might be found on a "real" board? "
the frequency of the slate tone, is however high you decide to talk, trick question. Though theres usually a 740/1khz tone for audio hanging out too. Youll find it in the oscillator section, and usually another switch by the talkback module
"8. Can you tell me how an 1176 physically hooks up? "
OIld ones were on terminal strips, new ones have terminal strips and XLR's
"9. Have you ever used more than 2 1176's at once? "
Lucky for me I had an 1178, so no need, but Ive linked em before
"10. Have you ever used a C12?...and experimented with the polar patterns? "
Had 3 C-12's REAL ones, in the threads about how I M/S mic the overheads elsewhere on the BBS the C-12's were the mics of choice, but failing that 414's
"12. Who makes a 666 mic? "
EV
theres more than a few pros who hang on this BBS no need to get snooty like when you called me out on thedrum recording stuff
