Yes, the red trigger lever on the side of the switch.
Buy two switches and a drive-belt.
When they arrive I help you with instructions, don't forget the solder-iron OK
i got the belt and put it on...the motor is running and the flywheel is rolling but when i engage the pinch rollor to simulate a tape being on there the reverse, ff, record, stop button aren't doing anything noticable. is this right?
nevermind...got both switches engaged and now it works!
just need some advice on soldering.
i've got some Solder-It silver bearing paste? will this work ok? it's supposed to work with a lighter but i guess i need an iron to be working inside the case.
i don't know if it's a problem with the head or a magnetic thing but the 4th track is full of mess...reverb, clicking and hiss. the other tracks are great.
am i in trouble or is it an easy fix?
Could be the playback board has poor contact at the motherboard connection.
Did you try head-phone jack for listening or the RCA output ?
Same result on channel 4 with hiss and crackle ?
All other channels are clean and bright ?
i didn't notice anything different with the meter.
when i'm recording in sync the meters aren't really giving a reading. i guess that's how it's supposed to be?
That's good, did you clean all heads properly ?
If so, I think the earlier post with poor contact between channel 4 board and motherboard need attention.
Tight to reach but can be done
