when you say "ideally lpr35" do you mean that tape is better than the sm911 generally or that it's better suited for this specific machine?
also with the take up reels i have the large hubs on so which one do i need?
1/4" x 7" Plastic Reel /small hub
or
1/2" x 7" Plastic Reel /high torque, no tape slot
also, i'm still looking for the switch if someone could point me to it.
I meant better suited but it's a toss up really, especially that the 3440 will work fine with SM911 as well, especially that it's much cheaper than LPR35.
The LPR35 and SM911 are identical, with the only exception that the LPR35 is 1mil and is closest to the Maxell UD 35 [also 1mil] for which the 3440 was originally setup for, as per the manual.
You can, however, use SM911 without ill effect and with great results. It's your call actually and that you can get SM911 for $15 bucks makes it easy to choose.
Well, you can take off the large plastic HUBS easily and use the 7" reels. It's much less expensive that way.
You want to get the:
or
1/4" x 7" Plastic Reel /w box
[I'd go with this one 'cause it has a box included for an extra dollar or so]
As far as the switch, you should post a separate thread / question on this and see if that helps.
